Author Topic: Location of thermostat  (Read 4946 times)
« on: June 18, 2020, 10:12:31 AM »
Morning all, I've been fixing a gear linkage issue and traced a water leak to the thermostat pipe work. The reason for mentioning gear linkage is it's fouling on the back of the thermostat housing so a good opportunity to fix both issues.
I'm trying to keep things original and struggling to believe this is "by design". I suspect the back pipe is fitted further back than it needs to be so a little too short. I can lengthen it but then I spotted a few other images within this thread http://www.lanciabeta.co.uk/forum/index.php?topic=4074.0 that show pipes curved around the gear linkage, or straight pipes where the thermostat is relocated.
So perhaps the question is, is the correct location for the thermostat further forward towards the radiator fan?
« Last Edit: June 18, 2020, 10:14:07 AM by JohnFol »
Re: Location of thermostat
« Reply #1 on: June 18, 2020, 11:13:19 AM »
That does not look like an original thermostat, but maybe on later cars they changed? This may be why it is sitting so close to the gear linkage?
« Reply #2 on: June 18, 2020, 11:58:53 AM »
Hi John
The solution will be longer hoses. Specifically the straight hose and the 90 degree hose. There are countless potential suppliers. I would use Car builder solutions if they have the sizes in black silicon and get new stainless clips to go with the 2 new hoses because the existing clips are likely to be corroded or semi seized. Coolant drain down is covered in the Haynes manual. Maybe do a system and radiator clean/ flush to reduce the chance of issues later.
NB Test the thermostat when you have it removed. Beta Thermostats vary hugely in price. You can convert to a Gates TH15587 87 degree from a Lada but get the stat first then the pipes.
Enjoy
Offline Sandro
« Reply #3 on: June 19, 2020, 10:30:02 AM »
Hi John
Enjoy
While on this topic I'm planning to drain / flush and replace the Coolant on my 84 injected HPE, I'd like a good handbook to assist carrying out this as well as other tasks. Does anyone know if there's a workshop manual made for later models ? or is Haynes' workshop manual 1973-1980 as good or as close as you get ?
Thank you, and please excuse the slight diversion off the original topic.
A.
1972 Honda cub
1984 Silver 2000i HPE
2005 Opel Vectra ( everyday )
« Reply #4 on: June 19, 2020, 11:35:50 AM »
The Haynes Manual is good enough for
have 2 bowls
set the heater on hot
undo the drain at the back of the block
undo the drain at the base of the radiator or remove the lower hose.
Remove radiator and flush through with a hose from top to bottom until it runs clear.
Remove thermostat and test in a pan of water with a Jam thermometer for open and close at the right temps
if the header tank is filthy remove it and clean it. NB if there is oil scum be aware you may have a blown head gasket.
Put it back together and run with flushing agent to the instructions.
When done fill with fresh antifreeze and water to at least a 30% concentration.
I missed out the swearing and cups of tea, but that should do.
« Reply #5 on: June 19, 2020, 09:30:26 PM »
Hi John
Enjoy
A.
The Haynes is ok for the basics, it doesn't cover all the later variations so don't rely on it too much but most things stayed very similar over the years. There is a French language one that covers later cars but to be honest the official publications are the most useful, if you need any technical info you are welcome to message me as I have most of the later books (not all in English but even I can get the gist) and can photograph anything you need.
Offline Sandro
« Reply #6 on: June 20, 2020, 03:08:24 PM »
Thank you Eric and Rossocorsa that's a great help.
That gives me enough information to clean out and replace the Coolant. I will get hold of a Haynes Workshop Manual as a matter of course.
( The Jam thermometer is a useful tip :) ..In anycase, I'll give it a go, Your 'Oil in the Header' comment was of slight concern however as I found some fine scaly deposits
sitting on the surface of the liquid on inspecting the contents of the Header receptacle. ( see below ) hopefully it's some other kind of residue. ( fingers crossed )
Rossocorsa thank you for your offer to help out with details for later models, it's mainly the Digiplex, digital advance ignition system that I'd like to get to know better because I understand
that they sometimes can be troublesome.
Thanks again, Andrew
1972 Honda cub
