Author Topic: Water pump to rear coolant rail interface  (Read 6024 times)
« on: January 28, 2021, 07:39:08 PM »
Simple question - does the o-ring suffice or should one also use a gasket? If it's the latter I'll probably have to resort to making one, as I don't appear to have one in my full engine set...
Re: Water pump to rear coolant rail interface
« Reply #1 on: January 29, 2021, 09:48:13 AM »
I made a gasket. I was not prepared to trust the o ring alone.
« Reply #2 on: January 29, 2021, 01:59:12 PM »
Thanks Eric. I'll do the same.
« Reply #3 on: January 29, 2021, 03:23:37 PM »
It’s worth checking the flatness of the flange. They can bow a bit hence the leaks. I always run a flat stone over the flange to true it up.
« Reply #4 on: January 29, 2021, 03:56:54 PM »
Good point. I'll do that when I'm next in the proximity of the part in question.
Cheers,
« Reply #5 on: January 24, 2026, 03:37:43 PM »
I was wondering all this.  I did find what looks the same but a gasket on other twin-cam models
https://www.aecar.co.uk/products/gasket-water-pump-to-pipe-lancia-delta-integrale-evolution-5999294?variant=1776666945
I will check for flatness also.  do I use the o-ring and gasket, or is that silly?  Do I use other products like wellseal on the gasket?
M
Offline Ics19
« Reply #6 on: January 24, 2026, 11:54:00 PM »
The Delta is a different pump and symmetrical gasket - you need the stock Montecarlo gasket which is offset and never in the kits:
https://www.eurosport-uk.net/shop/index.php?main_page=product_info&cPath=24_26&products_id=959
The gasket works well on the monte with a spray coat of blue Hylomar, it didn't have the O-ring on its flange  (y)
« Last Edit: January 24, 2026, 11:56:42 PM by Ics19 »
« Reply #7 on: January 25, 2026, 11:53:16 AM »
Mine is holding up with just the O ring and a generous
dollop of blue Hylomar. I may have used a slightly fatter ring.
Mark, if this is a new after-market rail, check that the flange is orientated
correctly in relation to the mount at the other end.
« Reply #8 on: January 25, 2026, 06:10:20 PM »
I am going to use the original I am pretty sure OEM bottom rail as the stainless one is not quite the right dims.  Top aftermarket stainless steel one looks good and has the mod for the coolant in and out from the back of the head.  I make a call on o-ring or gasket later this week.  It had a o-ring one fitted and wasnt leaking.  Mind you I now have a new pump fitted so that will sure make it leak  :P
Thanks for advice as per :-)
