Author Topic: The need for a remote fan switch  (Read 4228 times)
« on: June 22, 2021, 06:09:18 PM »
My car had a switch added to the dashboard to allow the driver to turn on the radiator fan. Seems this is a common thing, rather than a previous owner not fixing things properly.
So here is my question. If the automatically operated thermostatic fan switch works correctly, why is a remote manual switch required?
Re: The need for a remote fan switch
« Reply #1 on: June 22, 2021, 06:32:22 PM »
Hi John,
If the rad switch is working well, no back-up is needed.
However, if it's suspect, or if stop/start traffic on hot days is a regular occurrence,
having that dash option could be your get-out-of-jail card.
« Reply #2 on: June 22, 2021, 06:44:48 PM »
This is the UK so regular stops in traffic, but not regular hot days!
Offline GerardJPC
« Reply #3 on: June 22, 2021, 07:12:24 PM »
I think that a switch for the fan is a good idea for city traffic in summer.  You can bring the fan on a bit earlier and mitigate the level of heat in the engine bay, which may have knock on effects on the fuelling.
1973 Lancia 2000 HF Coupe
1982 Moto Guzzi V50 Monza
1982 Moto Guzzi V35 Imola
1983 Land Rover Series 3 88
2009 Jaguar XK Coupe 5.0
« Reply #4 on: June 23, 2021, 08:23:42 AM »
I fit one routinely even though I have ECU and Rad sensor switching. I want the option because stuck in traffic somewhere hot with a fully loaded car is no time to not see the fans kick in.
PS I use rotary switches because they are compact and do not get accidentally knocked on.
« Reply #5 on: June 23, 2021, 09:14:01 AM »
Sounds sensible. I might try and find an illuminated rocker switch so I know it's on.
Eric / all, do you also stick a timer on the manual switch so it stays on for a period of time after the ignition goes off?
