Author Topic: Cambelt idler tensioner  (Read 2764 times)
Offline the_matrix_master
« on: August 24, 2022, 05:43:08 PM »
My local garage is replacing the cambelt on my 1600 carb 1975 beta and says it needs the idler replacing any ideas of the part number and were to source one from.
Also require a new oil filter is the part required a Mahle OC473 again sourcing info if possible
Re: Cambelt idler tensioner
« Reply #1 on: August 24, 2022, 07:29:52 PM »
The OE idler has a circlip and the bearing can be replaced. Non OE can be sealed so need the whole assembly which is a bit more difficult to find. The bearing itself is easy to find.
A quick Google on the filter should find one for you
« Last Edit: August 24, 2022, 09:14:59 PM by peteracs »
« Reply #2 on: August 24, 2022, 09:01:45 PM »
Any ideas where to start in sourcing a stockist for either the replacement bearing or sealed unit ?
Checked Betaboyz parts and nothing there
« Reply #3 on: August 24, 2022, 09:20:32 PM »
See this thread
http://www.lanciabeta.co.uk/forum/index.php?topic=4078.0
Remember the complete tensioner pulley is different for 1600 and 2000 in diameter but the bearing is the same for both
As to stockist on the bearing any decent bearing supplier will have them, sorry no idea on complete assembly
« Reply #4 on: August 24, 2022, 10:19:18 PM »
Hi Matrix,
Just read your PM and thought i'd put this here.
I got mine from RS under the part number 3205-A-2RSITN9/HT33
This is just the bearing, it fitted with no effort into my carrier. I think
it is held in with a circlip, and is a loose interference fit.
Hope that helps
« Reply #5 on: August 24, 2022, 10:31:25 PM »
Thanks Nigel I'll give them a try
I have been looking direct from suppliers e.g. Ricambo and on Ebay prices are all over the place from £25 to over £100 and each time they say they fit Beta but they seem too large at 28mm diameter
Some sites asks for the OEM part number which I don't know and without that can't get much further but may be able to make some progress now
« Reply #6 on: August 24, 2022, 11:16:50 PM »
Just checked, I bought 2RS1TN9/MT33 SKF from Bearing King LTD earlier this year, price was £34 delivered.
« Reply #7 on: August 24, 2022, 11:20:14 PM »
Thanks Peter
