Back from Gerry's and a couple of days on the car. Fuel line completed and connected to the pump. The majority of the generic brake pipe clips turned out to be too loose in the original holes and I wasn't prepared to drill new ones so the old, original clips have been cleaned up and the best of them used instead, lucking, with no return pipe on the tank the tripe ones (which were the most damaged) could be replaced with doubles (5/16 & 3/16). With all the pipework routed I could reattach the steering arms so I can push the car out of the garage and turn it around when the time comes to start building up the passenger door. Maybe next week.
I've also hung the rear exhaust mounts just to get them out of the way. The jack bracketry has been powder coated and is now installed, thank you Mark Ferris for the pointers where it had to live. Sadly it meant drilling two holes in the box section as they weren't reinstated when the shell was restored (because they had been plated over poorly!). The jack now sits, where it belongs, behind the carpet. I noticed a couple of holes in the carpet and one lines up with an existing hole so there must be some retaining plugs to keep it in place. They'll be standard Fiat ones so no panic there! And talking of carpet, an hour or so with the hoover got them looking reasonable but I think the one on the floor will need the attention of a professional valeter to get the stains out. THey're not as bad as they look but it should be better. I've stashed the toolkit on the right side of the boot for now but think it belongs behind the carpet near the jack. It can stay where it is until the right fixings appear.
My memory of the first Beta HPE I had was that the carpet sat on a piece of hardboard. I'd like to do that with the Coupe in time. Should it have one?
Next week I have a couple more bits to drop off for powder coating and some handbrake mechanism parts for plating. Once I get them back the handbrake cable can go on with the cover and the exhaust heatshield. I may even be able to hang the rear and centre sections to get some shelf space back! They will need a coat of barbecue paint first and I've got a tailpipe trim on the way which should slip over the end of the straight pipe I went for. (the Laser variant).
That's it for this week I think. A beer or two is needed next!
