As most of you know I have a 2 litre Coupe. Common across the whole range of Beta's except the Montecarlo about which I know not as much as i should! My only experience was a part ownership many many years ago. By which I mean the part I owned was a centre tub for an 037 replica that never happened - another story.
I've been offered a Montecarlo engine and gearbox and, possibly, a second gearbox but I suspect that these might not be interchangeable with the FWD Beta. Pictures of driveshafts that I've seen show a long and a short one which leads me to suspect that the mounting points on the block for the intermediate shaft are absent on the Montecarlo. I'm also aware of the camber mounted distributor and wondered if that would foul the underside of a Beta bonnet? Then there's the sump pan and, presumably, the oil pump too? What about the box? Obviously it's hydraulically operated but capable of cable conversion but is the final drive ratio the same as the Coupe?
Over to the Montecarlo experts!
If there is anyone in the group who could make better used of these parts (I think they're located in Yorkshire but haven't asked that question) please let me know by PM and I'll happily put you in touch! Assuming that it's not a suitable engine/box for the Beta Coupe!
