Author Topic: Aux shaft and crank oil seals  (Read 7466 times)
« on: April 17, 2023, 03:05:33 PM »
Afternoon all, I'm fairly sure my aux shaft or the seal behind the pulley wheel has a leak. Haynes shows enough detail for me to take the job on, but their starting point is engine out of car. Has anyone tackled these whilst the engine is till fitted?
Re: Aux shaft and crank oil seals
« Reply #1 on: April 24, 2023, 03:57:16 PM »
Should be OK to do through the wheelarch. It's possible you may have to drop or raise the engine slightly to wiggle the central bolt out.
« Reply #2 on: April 24, 2023, 05:18:01 PM »
Thanks for that. Helps me decide if it's a 1 day DIY job or a "lets get the engine overhauled whilst it's out" job
« Reply #3 on: April 24, 2023, 10:01:47 PM »
Hi John
I had a nightmare of a job getting the bolt loose on the first engine I tried. The second with the help of a decent rattle gun it came out easily.
« Reply #4 on: October 29, 2025, 10:52:54 PM »
John did you manage to do this in the end?  I think this is on my list
