Author Topic: Can you guess what it is yet?  (Read 1897 times)
« on: May 25, 2023, 06:04:54 PM »
For scale, it's 250mm (10 inches) long.
Re: Can you guess what it is yet?
« Reply #1 on: May 26, 2023, 05:19:56 PM »
Some sort of water pump pulley holder?
« Reply #2 on: May 26, 2023, 05:56:58 PM »
Spot on, Eric. I didn't think it would take long for someone to get it. When I get back to my PC I'll post a pic of it in its working environment.
All this was instigated by the fun and games I had getting the water pump pulley off the (broken) engine in France. I swore that I would fab something to avoid going through that particular circle of hell again.
For anyone that's interested, distance between bolt centres is 36mm and a 15mm hole allows a 13mm bolt head to pass snugly through. I used a pillar drill and 15mm blacksmith bit to make the holes and a die grinder with cylindrical burr to make the ellipse. It had its first test when removing the cap head bolts I had foolishly used to secure the pulley to the pump on the 'new' engine. Having done battle with those bolts in situ I quickly realised that using cap head screws was madness - you'd never have clearance to remove them.
I'm pleased to report that the tool did its job without any dramas.
« Reply #3 on: May 27, 2023, 02:11:49 PM »
As promised, a pic of the tool fitted to a water pump.
