Author Topic: Inlet valve needed.  (Read 3587 times)
Offline simplydelboy
Inlet valve needed.
« on: June 08, 2023, 10:51:53 AM »
Somewhat bizarrely after an engine rebuild no. 1 inlet valve bent during startup. Can’t see any other damage and don’t know what caused it. Has anyone got a spare? Head diameter is 42mm so it’s the later series. Thanks in advance,
Del
1977 Beta Spyder 2000
1983 Beta HPE 2000ie
Re: Inlet valve needed.
« Reply #1 on: June 08, 2023, 11:13:33 AM »
Hi Del, I've used these guys for a few engine bits, and they list inlet valves. Might be worth a check..
https://www.aecar.co.uk/products/inlet-valve-fiat-lancia-twin-cam-4255694?_pos=25&_sid=4447ce872&_ss=r
« Reply #2 on: June 08, 2023, 01:01:19 PM »
Hi John, thanks so much for the info. I’ve left a message with them and hope they have the valve. Betaboyz sadly out of stock. Bloody annoying as the rebuild went so well until this issue. Ah well, cars!!!
« Reply #3 on: June 08, 2023, 01:57:16 PM »
I have some spare heads complete and can take a valve out if you want to use a used one?
« Reply #4 on: June 08, 2023, 04:10:56 PM »
Hi Peter, yes a used one is no problem, I’ll just lap it in. If it’s not a lot of trouble. Let me know the cost, thanks,
Del
« Reply #5 on: June 08, 2023, 06:56:51 PM »
Hi Del
Not a problem, I will have a look at my heads tomorrow and get back to you.
« Reply #6 on: June 08, 2023, 08:28:55 PM »
Thanks Peter.
« Reply #7 on: June 09, 2023, 08:57:55 AM »
I take it you cambelt was fitted correctly Derek? One tooth out can bend a valve.
« Reply #8 on: June 09, 2023, 03:10:02 PM »
Hi Neil, see my email. I’m sure we set it ok. Tried to put a pic on this reply but couldn’t get it to work.
« Reply #9 on: June 09, 2023, 03:11:14 PM »
I see it did work!! It wasn’t on the preview so I assumed it hadn’t worked!!
« Reply #10 on: June 09, 2023, 04:03:12 PM »
Hi Axel
Please send your address via messages and I will get a couple out to you.
