Author Topic: Wing to valance connection?  (Read 2411 times)
« on: June 29, 2024, 10:55:47 AM »
There is a layer of what appears to be aluminium foil about 30mm wide,
the width of the join, between the wing and front panel.
What function does this play?
Re: Wing to valance connection?
« Reply #1 on: June 29, 2024, 12:02:15 PM »
Happy to be corrected but I’ve always suspected it maybe zinc to help reduce corrosion. Think I’ve also seen it under the bonnet and door hinges on some cars.
I came up with this belief as I couldn’t come up with a better theory.
Can’t imagine it would be aluminium as that would surely promote corrosion?
« Reply #2 on: June 29, 2024, 12:54:17 PM »
I think you're correct Ian.
It is more likely Zinc.
I don't think I'll be trying to replicate.
