Author Topic: Transverse link rod ends  (Read 3058 times)
Offline WurldBeta
« on: September 17, 2024, 08:16:11 PM »
Hi there, hope you're all well.  Does anybody have a part number (or any pertinent info) for the rear transverse link bearing rod ends? I'm taking off the rear suspension to refresh and wanted to short circuit the hunt for them.
Re: Transverse link rod ends
« Reply #1 on: September 17, 2024, 11:04:42 PM »
Hi, you should be able to find the bushes here on Mark’s site
https://353652584127257704.weebly.com/store/c16/Suspension_Bushes.html
Offline WurldBeta
« Reply #2 on: September 19, 2024, 03:43:44 PM »
Thanks for the info Peter.
Both of the pressed metal and the tubular transverse links are subject to a lot of forces. They could be improved dramatically over standard. Anyway, I was just wondering if anybody knows the spec on the metal rod ends with the eyelets sizes? I've done a rough measurement on thread length, pitch and diameter but I haven't pressed rubber bush out as I'm without a press, I'm unsure what to look for in terms of replacements.
Regards
Glenn
« Reply #3 on: September 19, 2024, 06:39:57 PM »
If the polybushes weren't available from Mark I would have used the pressed ones as a pattern for the length and bought a few sets (four minimum) of left and right hand thread weldable bushes, a length of thick wall tube and matching sets of Rose Joints in left and right threads with the correct diameter centres to match the standard bolts and built a set and had them plated and painted.
The trouble with Rose Joints is that they have zero compliance and are excellent at transmitting noise. They can also wear quicker than poly bushes, especially if protective rubber boots fail.
https://www.ebay.co.uk/itm/271530393242?_skw=threaded+tube+for+left+and+right+hand+threads&itmmeta=01J85NHB490BM4WGGGZ47NACR1&hash=item3f3878fe9a:g:9dMAAOSwcnpTqG29&itmprp=enc%3AAQAJAAABAHoV3kP08IDx%2BKZ9MfhVJKm9xvx5YLk9mzI5S2%2BiYEomMCysmONobxq4Iyir8WhAzEDDxO%2BJpz1TIbfppEmWVH71vqkqpfFHte5MetPME0B6FhiZzX8sJbioirzIhrWtdqiTO8PNePJK9xrtVYnxbmb60PHmrZgk3ieEPjJFmXOVNttk5xvHRsXH2arPe5uxGdf0aF23kj1yqH0DHwsrIXSdcCVLAZENUwa0PLXWaedecC7BQ%2FqS%2FyOPFNeDB2e0ozAFv%2BNJTH65jV69ytXBWokc%2Bg1UjpHfhOCEJ776eCeE1AjHS3sy49RmuTUSQqYhXM9BvVAqtDst18ojiNMen3g%3D%7Ctkp%3ABk9SR6qyxbXBZA
Other suppliers available!
Offline neromoto
« Reply #4 on: September 20, 2024, 03:46:20 AM »
If you live in Canada, USA shops may be more convenient.
https://www.midwest-bayless.com/c-88-control-arms-links-bushings_LANCIA-BETA-0.aspx
Thema 8.32 S2 1990
Gamma Berlina S1 1978
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
