Author Topic: Beta Door Card Clips  (Read 2809 times)
Offline Pbraith1
« on: October 25, 2024, 08:07:35 AM »
There seems to be few original door card clips available, and if they are the prices are very high - I saw one at £20 per clip.
I did some research and found this alternative route which works superbly so I thought I would mention this on this forum as it might  be useful.
You can also search the OEM numbers for many suppliers.
These clips work for the beta door cards, just saw or file out the middle band and remove the clear plastic clip receptors on the doors.
Best to open up the door cards behind the hardboard with a screw driver for easy fit, twist each clip into the slot.
8mm Interior Trim Clip / Fastener for Trim Panel, Door Card.
OEM Part numbers : BMW 51411973500, FORD 99950758240
https://www.ebay.co.uk/itm/371434464771?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=aiUWzZxKTF2&sssrc=4429486&ssuid
Re: Beta Door Card Clips
« Reply #1 on: June 29, 2025, 03:51:29 PM »
lets give this a go.  Mine are all rubbish.
