Author Topic: 1981 Zagato PAS Tie Rod Ends?  (Read 5706 times)
Offline alsgro33
« on: November 14, 2024, 07:26:10 PM »
Well, the shocks are in, but noticed when doing that job that the tie rods are destroyed. Anyone know where I can find replacements? Did not realize they would also be tough to source. Mine are the "unthreaded" kind that screw onto the track rod, I believe...
Re: 1981 Zagato PAS Tie Rod Ends?
« Reply #1 on: November 14, 2024, 10:36:56 PM »
Assuming the standard ZF power steering rack, Mark has them in stock.
https://353652584127257704.weebly.com/store/p56/ZF_Power_Steering_Track_Rod_End.html
They are slightly odd sizing and not commonly available when I tried to source them.
Offline alsgro33
« Reply #2 on: November 15, 2024, 05:41:47 PM »
Thanks! Mark's site wasn't loading for me here in California, but today it's back. Maybe someone kinked the fiber cables across the Atlantic?
Anyway, coming from owning a few Fiat 124s, I didn't realize sourcing parts for the Beta would be such a challenge! Appreciate it.
Offline alsgro33
« Reply #3 on: November 19, 2024, 05:34:08 PM »
Has anyone ever experienced this? I grabbed the tie rods off the (ZF) zagato yesterday, and the driver's side seems to be a larger threaded section than the passenger side.
Maybe this was from some earlier repair job?  Not sure if this is normal or the best way forward. Any help/thoughts appreciated!
« Reply #4 on: November 19, 2024, 05:51:12 PM »
You might have 1 steering arm from a non PAS rack and 1 correct one for PAS which are more substantial with bigger track rod ends. 16mm fine pitch from memory. I think non PAS Racks are 14mm fine pitch.
I might have uploaded PAS rack pictures in my members vehicle area. Note I converted my UK Beta Spyder to PAS from a VX Coupe.
Offline alsgro33
« Reply #5 on: November 19, 2024, 10:12:47 PM »
Thanks for the reply. I just looked up the part # printed on the 'bigger' track rod end, and it's actually coming up as a Porsche part... Weird. Someone must have gotten creative at some point in this car's life... Thanks for the response.
« Reply #6 on: November 19, 2024, 11:02:56 PM »
Just to confirm they should both be the same and yes suspect the Porsche one was due to not being able to find a correct one due to being hard to find…..
