Author Topic: Curious suspension part in U.K.  (Read 3950 times)
« on: January 05, 2025, 01:23:31 PM »
Hi All
Whilst sorting out strut parts for rebuilding my struts, I came across these hard plastic spring supports which fit on the front struts (completely different to the rear ones which are normally found).
This reminded me of the post from a while ago here
http://www.lanciabeta.co.uk/forum/index.php?topic=5162.0
I have no idea which set of struts they came from and have measured the two sets of front springs which are the normal 391mm high uncompressed as per previous posts.
So I had a quick look in the old paper parts book, no mention, just the normal thin rubber supports on the front, however on the pdf posted on here for the up to 1984 cars the front struts have this hard plastic support as well as the normal rubber as well as differing springs but only for the Australian market. I have therefore no idea how I managed the acquire a pair.
Nigel, would be interested if your Aus car had these when you changed the struts?
Re: Curious suspension part in U.K.
« Reply #1 on: January 05, 2025, 04:01:20 PM »
I have no recollection of what was there.
When the weather improves I'll take a look underneath.
Cheers, Nigel
« Reply #2 on: January 05, 2025, 07:03:58 PM »
I have a pair too (one cracked) is spares from a scrapped HPE VX.... I was looking at them today and did not know what or where they cam from....
« Reply #3 on: January 05, 2025, 11:35:08 PM »
Hi Tim
Interestingly I think they came from the IE Coupe, so wonder if they used them on later cars? Though with standard length springs, maybe the extra engine weight needed this extra 1cm height?
« Reply #4 on: April 29, 2025, 09:39:12 PM »
Cheers, Nigel
Peter,
Having stripped down my front struts again, I can confirm I've got those hard plastic
discs between the steel and rubber.
