Author Topic: How to remove the front grille.  (Read 2324 times)
Offline neromoto
  • Country: jp
« on: February 26, 2025, 03:37:03 AM »
I tried to remove the grille.
However, I tried to remove the top screw and pull the grille upwards, but it hit the hinge and would not pull out.
I tried to pull it out upwards because the lower claw of the grille is an insert.
In this case, is it safe to tilt the upper part of the grille forward?
Or do I have to remove the bonnet hinges?
Masataka
Thema 8.32 S2 1990
Gamma Berlina S1 1978
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
Re: How to remove the front grille.
« Reply #1 on: February 26, 2025, 02:15:37 PM »
I had the same problem. If you loosen the bonnet bolts attached to the crossmember, but not remove them, you can move the bonnet upwards just enough to get the grill out if I remember correctly.
Offline neromoto
  • Country: jp
« Reply #2 on: February 27, 2025, 02:16:56 AM »
Hello Peter
Thanks for the advice.
After all, the grill can't be easily removed.
I'll try it again the next time.
Masataka
Thema 8.32 S2 1990
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
Offline neromoto
  • Country: jp
« Reply #3 on: March 03, 2025, 12:59:29 PM »
I was able to remove the grille. Thank you.
Thema 8.32 S2 1990
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
