Author Topic: Inner wing metalwork question  (Read 2813 times)
« on: April 09, 2025, 03:53:25 PM »
Just trying to sort out the removable panels on the inner front wing on the IE/VX Coupe.
I think I have what I need, which is a large removable panel on the right hand side which has two inspection holes and rubber bungs in it, and a small panel near the brake pipe unions on the left hand side.
Is this all I need as I cannot find them on the fiche pdf which is posted here?
I also have the later inner wing liners which cover most of these.
Re: Inner wing metalwork question
« Reply #1 on: April 09, 2025, 04:36:37 PM »
That sounds right Peter. I posted a photo of my 'new' right hand panel on my '1300 Coupes' thread in 2023. As you say the left panel is smaller.
« Reply #2 on: April 09, 2025, 10:03:23 PM »
Peter, hi,
My car has the plastic inner arches in 2 sections, split at the 12 o'clock, which
incorporate the large area on both lower front sides. There is a small metal cover, as mentioned,
around the brake pipes on the left side.
« Reply #3 on: April 09, 2025, 11:37:37 PM »
Thanks Neil and Nigel, still unsure on the this very late front end should it have that large right hand panel or just the wing liner?
« Reply #4 on: April 10, 2025, 11:26:40 AM »
Should have added that my 2000ie's didn't have the metal panels, just the larger plastic wheel arch liners....
Neil
