Author Topic: New nember having trouble fitting window winder mechanism.  (Read 4730 times)
Offline Tig490
Guys I need your help!
I've been asked to fit new window winder mechanism to a Lancia Beta, I got them both fitted but I'm not happy on how it's turned out.
The window will happily go up about 3/4's of the way then start to go stiff to turn when cranking the handle.
Before I fitted the 2nd one I noticed the original one had a bow in the middle of the vertical section so I tried to copy that on the new part...... I believe it has helped as the window will go up more but not all the way.
The bracket holes don't line up very well!...... the 2nd one I've fitted I've only got 1 bolted fitted, the 2nd bolt hole is miles out.
Can you guy's help me?
Re: New nember having trouble fitting window winder mechanism.
« Reply #1 on: May 07, 2025, 09:17:29 PM »
Hi,
Some pointers:
It's good to make sure the assembly works well on the bench, and that
the split tube is evenly open all the way. Any kinks will impede the motion. Engine oil
should be used to lube the spiral, not grease.
When fitting, the forward window channel is best removed for access. Hold the window up the
top with sticky tape. Rotate the unit into position, the mounting holes should all line up give or take a few mils.
Once it's in, check again for correct ops without the window connected.
Refit that front lower window guide channel, making sure the tag at the top
is properly located in the upper channel and that the rubber/felt guide is in place correctly.
Then test the free movement of the window by hand.
If all seems ok, connect the two parts together with the two 6mm bolts.
You'll find the window likes to be tilted slightly forward. Silicon spray in the channels helps.
Good luck!
Offline Tig490
« Reply #2 on: May 10, 2025, 10:22:01 AM »
Thanks Nigel I will try that over the weekend.
Offline smithymc
« Reply #3 on: May 27, 2025, 08:37:01 PM »
Never an easy job, but if you are trying to fit one of the DG Rally supplied ones, you are not alone in having problems- the holes on the window carrier plate appear to be in the wrong pattern and need another hole forming- I'll have a go and post how I get on.
Offline smithymc
« Reply #4 on: May 30, 2025, 02:43:27 PM »
On a further attempt, the holes on the window carrier channel are also mis-positioned. The 'spare' length of channel below the bottom bolt is also c 15mm too long  (for a coupe door anyway) and and fouls the bottom of the door.
Hope others are having more fun than I am and might share the secret.
All fun!
Offline smithymc
« Reply #5 on: May 30, 2025, 04:29:21 PM »
The replacement regulator is straight as opposed to the curved original which moves some of the holes centres.
I'm a bit puzzled to be honest and wonder if it's my car being relatively early that is the issue?
Offline smithymc
« Reply #6 on: May 30, 2025, 04:31:35 PM »
Measurements.
Replacement
Offline smithymc
« Reply #7 on: May 30, 2025, 04:31:57 PM »
Original
« Reply #8 on: July 01, 2025, 12:36:22 PM »
Thats very Lancia..... I don't know but I'd hazzard a guess that they are different between Berlina and all the others?
