Author Topic: Cam-Belt tensioner spring bolt replacement  (Read 4306 times)
« on: August 15, 2025, 10:14:40 PM »
When I was doing the Can-Belt I sort of broke the hexagon bolt thingy that supports the spring.  I hardly touched it, honest!
Any thoughts where I can get one?  I have been searching Fiat and Lancia suppliers but not found one yet.
Re: Cam-Belt tensioner spring bolt replacement
« Reply #1 on: August 15, 2025, 11:06:04 PM »
Nigel from the Fiat 131 rebuild YT page suggested a bolt with a locknut.  I will compare the diameter when I get home.  If that works I will start thinking about getting the broken thread out.
M
« Reply #2 on: August 16, 2025, 07:42:49 AM »
Hi Mark
I should have a spare one from the engines I stripped. Will check later today.
« Reply #3 on: January 17, 2026, 11:13:58 PM »
Yay!  All done.
made a very slight groove in it with a Dremel.  Pluz-Gas and then its slowly came out.  Thanks Peter for the replacement.
M
