Author Topic: Splitting headlights  (Read 5427 times)
« on: January 02, 2010, 10:41:02 PM »
If there a simple way to remove the two reflectors (ie the headlamp bowls themselves) from the single piece headlight units  ?
Also I havea spare set where the headlights inside the unit have a glass on them with a beam pattern  - is that correct of hase someone bodged them ?
Thanks,
Stuart
Re: Splitting headlights
« Reply #1 on: January 04, 2010, 03:20:06 PM »
if they are anything like the Gamma units, slowly cut through the mastic until you can
pop the glass out and the reflectors can then be pulled off the clips.
