Author Topic: Starter Motor Removal - Any tips!  (Read 7501 times)
Offline spyder_resto
  • Simon
    • www.betaspyder.co.uk
« on: October 06, 2025, 09:57:50 AM »
Hi All,
I have now got my 2.0 lancia beta running on the fuel from fuel tank.
But during an attempt to start it smoke came out of my starter motor and i will need to replace it.
Is it hard to remove and replace the starter ?
Any tips would be appreciated.
Simon
Re: Starter Motor Removal - Any tips!
« Reply #1 on: October 06, 2025, 10:24:35 AM »
Very simple  - the long bolts into the bellhousing and the bracket at the rear.  Access is a bit easier if you take the inlet off but it's not essential.
« Reply #2 on: October 06, 2025, 10:40:52 AM »
or Rad out maybe?  I wanted to do this anyway and got a good view of everything under the IM
Merc EQA
« Reply #3 on: October 06, 2025, 11:34:40 AM »
I've always done the radiator out method as it's easier access through the grill that leaning over the bonnet..
Also took the opportunity to replace with a high torque, and much lighter unit from WOSP.
« Reply #4 on: October 06, 2025, 02:52:57 PM »
That is so cute.  Is it good?
Merc EQA
« Reply #5 on: October 06, 2025, 04:07:38 PM »
It starts the car .... . .  :D
  • Simon
« Reply #6 on: October 06, 2025, 04:46:17 PM »
Thanks for the responses. I have a spare one so will check if that one works otherwise will get the one that smoked repaired.
Thanks for the responses everyone!
Si
  • Simon
« Reply #7 on: October 06, 2025, 11:01:11 PM »
ok. I have had a disaster.  :(
Was removing the starter motor and the bolt on closest to the engine (i.e the one on its own) has sheared off.
The two on the other side came out ok.
Any advice would be appreciated...
the head has sheared off and is stuck inside the hole and there is no way for me to turn it
thanks
Si
« Reply #8 on: October 07, 2025, 03:27:50 PM »
Sounds suitably horrible place to have it happen. Are you able to remove the starter?
Depending how stuck the 'stud' is, then drilling and a stud extractor may work. Drilling may be a challenge of course. A photo may help get a better idea of the situation.
  • Simon
« Reply #9 on: October 07, 2025, 05:44:09 PM »
The starter moves but it is fixed with the last bolt. Looking at the length of other bolts there cannot be more than two or three threads on it holding it in.
Access is very tight indeed, am having to get to it through the wheel arch.  Have now ordered a extractor tool that I can turn with a socket so I can reach it via a very long extension.
Have drilled it out a bit using a bit extender which really helped so will try the extractor when it arrives but may have to mix that with a bit of heat!
Its never easy is it!
Will keep you informed
Si
« Reply #10 on: October 07, 2025, 09:00:03 PM »
Hope it works.  I have similar spring tension bolt snapped on my cam-belt tensioner.  Pictures also please.  Good luck
Merc EQA
  • Simon
« Reply #11 on: October 08, 2025, 09:26:33 AM »
Hi All
Does anyone know what the size of the starter motor bolts are please?
I have one snapped and the threads on the others are in very bad shape.
Would be good to replace..
thanks in advance
Si
  • Simon
« Reply #12 on: October 08, 2025, 09:45:03 AM »
looking at my parts catalogue it looks like the starter motor bolts are Lancia 14044721.
This is the same as Fiat 1407721
looks like they are M8 x 75. Can anyone please confirm?
Si
« Reply #13 on: October 08, 2025, 02:20:41 PM »
Its odd, all my Lancia genuine and Haynes manuals make no mention or torques.  My Lancia manuals normally has torques and bolt sizes but nothine.  This is odd
Merc EQA
« Reply #14 on: October 08, 2025, 02:47:16 PM »
If one has snapped but the others are out will the starter motor not slide out along the broken "stud"? There may be another bracket holding it to the front of the engine? You should be able to see it from underneath? Once the motor is out of the way you may find s day or two with penetrating oil and a mole wrench will get the remains out? I'm assuming that the bolt hasn't sheared at the threads of course!
« Reply #15 on: October 08, 2025, 06:00:21 PM »
If you are still having access issues, I'd suggest removing the
battery tray and other bits above such as water hoses etc. I had my radiator out and
grille off when I fitted the WOSP unit. Easy to get to.
I'm thinking the starter is held in by bolts with 13mm heads. If I'm
recalling correctly the bolts will be M8x1.25 i.e. the metric fine.
As Guy suggested, there may well be a bracket to the
block supporting the back of the starter.
  • Simon
« Reply #16 on: October 08, 2025, 08:51:02 PM »
Hi ,
I may well have to remove the battery tray and rad if I have no luck.
I had hoped it would slide out and then I could deal with the remains on the bench but when I hit the bolt remains with a screwdriver and hammer it would not move.
Am I correct in thinking that the hole in the gearbox casing is not threaded?
Si
« Reply #17 on: October 08, 2025, 09:56:52 PM »
Si,
No they are not threaded.
N
Offline JASPER_40
  • Country: au
« Reply #18 on: October 09, 2025, 08:49:38 AM »
I recently had my starter motor out and it was a bit of a pig of a job.
Mine had a bracket supporting the back of the starter and securing it to the block. This was difficult to remove as the space was very tight requiring slim hands, a good range of spanners and UJ's. I would suggest asking the wife to help therefore !  Also getting this bracket back in was worse.
Dont know why this bracket was even necessary as all other cars seems to just rely on the 3 bolts securing the starter to the bell housing.
I also had to remove the oil temp sender to gain enough wiggle room to manoeuver the starter out, which was also very tight. if you are further hindered by this obstinate bolt then I think you may not get the starter out at all without getting this bolt out first.
My car is an S3 with Air con and not sure if the procedure suggested here is the same as for all others.
This was an account of my struggle with the starter, for what it is worth.
Steve
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
  • Simon
« Reply #19 on: October 12, 2025, 06:30:37 PM »
Does anyone have pictures of the bracket please?
I could not see it on my car and could not see it in the Haynes manual.
thanks
Simon
« Last Edit: October 12, 2025, 06:35:36 PM by spyder_resto »
