Author Topic: Electrical  (Read 2285 times)
Offline Mario2612
Electrical
« on: December 23, 2025, 11:25:45 PM »
My beta hpe 2000ie has an issue with the alternator the warning light comes on when I switch on the heater fan I have had the alternator checked and replaced it with but this hasn’t sorted it out
Re: Electrical
« Reply #1 on: December 24, 2025, 06:57:15 AM »
What happens when you turn on your headlights?
If the same suspect wiring, if not then suspect faulty heater fan.
Ideally use a meter to monitor the actual voltage being produced.
Offline Mario2612
Re: Electrical
« Reply #2 on: December 28, 2025, 11:14:07 AM »
Thanks Peter heater fan is the problem nothing else affects it
Re: Electrical
« Reply #3 on: December 28, 2025, 02:37:13 PM »
Sounds like your heater fan needs replacing/refurbishing then, especially if no problem with the the lights and radiator fan. If the radiator fan is original that takes a high current which will show any weakness in you r alternator and wiring from it.
Re: Electrical
« Reply #4 on: December 28, 2025, 08:01:24 PM »
Are there any well trodden paths to replacement? For example a new fan from a fiat xyz is a direct swap and easily available?
Re: Electrical
« Reply #5 on: December 28, 2025, 10:46:16 PM »
 Never seen a request for one, so no idea.
Re: Electrical
« Reply #6 on: December 28, 2025, 11:20:28 PM »
Isn't there a resistor in the fan circuit that goes wonky? I'm not 100% sure I just have a vague memory of such things in Italian cars
Re: Electrical
« Reply #7 on: December 29, 2025, 10:02:22 AM »
The resistor lives on the front left inner wing behind the suspension turret. How about removing the connections and bridging them to see if the fan runs better? If you need a spare motor with the drums attached I've got one waiting to be thrown out. No guarantee on condition though! All I can do to check it is attach 12v and se what happens.
