Author Topic: New old Cylinder head  (Read 29614 times)
« on: January 26, 2026, 03:33:55 PM »
How do you know when a cylinder head has been skimmed too many times?  I have a feeling mine has been
Engineers called, cant remember the term but he said its been skimmed to a point below the valves.  I used Alan's loaned tools without really knowing what I am doing but had my suspicions...  I seem to remember that there was a lot of fresh air showing on the combustion camber to face gap and not the 0.25mm
« Last Edit: February 03, 2026, 06:16:09 PM by Ferrit »
Re: Cylinder head min height?
« Reply #1 on: January 26, 2026, 03:59:21 PM »
ahh Alan says the tool for the combustion chamber is for earlier engines
« Reply #2 on: January 26, 2026, 10:45:36 PM »
Hi Mark
MLS gaskets can be ordered in different thicknesses, so you can offset the height issue, but does not solve if the head becomes porous etc due to too much taken off.
« Reply #3 on: January 27, 2026, 12:38:51 PM »
Jon @ Stanwood says go and find another head.  Well at least I know now...
« Last Edit: January 27, 2026, 12:45:31 PM by Ferrit »
« Reply #4 on: January 27, 2026, 01:04:21 PM »
Hi Mark
Is that because it has been skimmed too often or for another reason?
I have spare ones if you need it.....
« Reply #5 on: January 27, 2026, 01:44:02 PM »
skimmed to the point the valve seats are through on the inlet side.  He said it can be done but you might create more issues skimming again.  Easier to find a new (er) head.
Alan is having a look for me, Peter do you have many heads spare?
« Reply #6 on: January 27, 2026, 01:59:58 PM »
Yes, have a couple spare which you are welcome to pick from.
« Reply #7 on: January 27, 2026, 06:17:45 PM »
I respect Stanwood Engineering on this. If you go looking outside of this group you want a Strada 105/130 TC of Lancia VX Head if you can find one. This gets you larger inlet valves and bigger ports. VX Units had Sodium filled exhaust valves which are now more of a risk of breakage than a blessing. Good new stainless Exhaust valves are not hard to find, but they need new compatible guides. A great core head now gives you options for the future. However there will be good core heads out there very cheaply. Good Luck.
« Reply #8 on: January 27, 2026, 06:59:40 PM »
I have a head (thank you Alan  (y) ).  Its a VX one.  So is AE Car the best place for valves and guides etc?
I will get it checked out before buying items of course.
« Reply #9 on: January 27, 2026, 07:24:54 PM »
Hi Mark
I bought my guides from AE and very happy with them.
« Reply #10 on: February 03, 2026, 06:06:23 PM »
Thanks Peter.  AE Car sell guides and valves, Eurosport UK sell valves and springs.
I am thinking I will need the lot to build up a bare head, valves, guides, springs and collets etc.  Re: head gasket, which make should I be buying, a MLS or is this just very a higher state of tune engines?
I was going to buy head bolts, gasket set and maybe guides and valves from AE Car.  Leaving:
Head gasket from where - they all seem the same to me?
Valve springs and top and bottom washers
collets
I might give AE Cars a call tomorrow.
I guess I can ask the companies mentioned above?
Re: New old Cylinder head
« Reply #11 on: February 04, 2026, 08:37:52 AM »
There is a late generation FL Astradur Head Gasket on eBay. It is expensive as expected. These are bond on resin gaskets. Note the heavy re-enforcement around the fire rings missing on nasty cheap items.   https://www.ebay.co.uk/itm/267543117735?var=0&shprz=EBAY_GB_131090&_ul=GB&mkevt=1&mkcid=1&toolid=20006&mkrid=710-53481-19255-0&campid=5338986375&loc_interest_ms=&loc_physical_ms=9046061&adtype=pla&customid=Cj0KCQiA-YvMBhDtARIsAHZuUzL1kxpnJynvP7cyKO8VL_DehGkbKUywb1MX6e3KY-VTV1K-J5G81rkaAmX_EALw_wcB|null|null&gad_source=1&gad_campaignid=20235105561&gbraid=0AAAAADcddnakATq8pHqLdkHJICX-qREj6&gclid=Cj0KCQiA-YvMBhDtARIsAHZuUzL1kxpnJynvP7cyKO8VL_DehGkbKUywb1MX6e3KY-VTV1K-J5G81rkaAmX_EALw_wcB#:~:text=Head%20Gasket%20for%20Lancia%20Beta%20Coupe%20Spider%20828BC%207030162%20Original
« Reply #12 on: February 04, 2026, 04:43:28 PM »
Weren't these supposed to be in special sealed packaging prior to use and only opened at the last minute before use? I had some misc fiat bits and there was one gasket in a laminated plastic wrapper probably originally vacuum sealed but unfortunately opened so I binned it
« Last Edit: February 04, 2026, 04:47:20 PM by rossocorsa »
Offline Ics19
« Reply #13 on: February 04, 2026, 05:06:38 PM »
« Last Edit: February 04, 2026, 05:11:57 PM by Ics19 »
« Reply #14 on: February 05, 2026, 12:03:16 PM »
I am thinking this is my best bet so far.  I cant get my head around using a possibly 40 year old HG  :o
https://www.aecar.co.uk/collections/spesso/products/head-gasket-spesso-racing-1-8mm-fiat-lancia-twin-cam-1982
« Reply #15 on: February 06, 2026, 08:37:16 AM »
My NOS gasket didn't seal as per my posts. Got a new one from Germany (Historic Racing).
« Reply #16 on: February 06, 2026, 08:52:00 AM »
You should definitely speak to Darren Cooksey at Monte Servicing and Repair about the price for a Cometic MLS Gasket. There is no resin to decay and you can re-use them. Interesting that Spesso will not support their gasket used on a VX. FL had so many head gasket fails with the VX they introduced these full resin bond gaskets. Neil's experience shows the scary reality of finding one fit to use.
« Reply #17 on: February 06, 2026, 09:58:35 AM »
Indeed odd given they should be ideal. My concern with the resin bonded gaskets was how thick the damn things were. With limited crush on them it made a real difference to the CR. The spide (when I finish the thing....) will be getting MLS
« Reply #18 on: February 06, 2026, 12:31:32 PM »
Hi Mark
Given the cost of that gasket, I would pay a bit more and go for a MLS, the pain in it failing again is a lot more than the extra you will pay would be my view.
« Reply #19 on: February 13, 2026, 09:30:11 AM »
I have a sneaking suspicion that the most recent issue I encountered on my Beta engine (after a full top end rebuild) was head gasket related. I can't be certain until I get the car up on ramps and start it up, but it has all the hallmarks. I used what I thought was a good quality head gasket from a sealed package but having read stories on here, I should have bought new from someone like Gloria Croft or used an MLS. Live and learn...
