Author Topic: Silly question.  (Read 36312 times)
Offline garethwd
Silly question.
« on: February 21, 2026, 08:30:08 AM »
To change the repeater indicator build .. Do I need to remove the arch liner? Or does the flasher pull off?
Re: Silly question.
« Reply #1 on: February 21, 2026, 08:50:06 AM »
Not silly at all....
The original fixing is via two small nuts on the inside of the wing, so yes you need to pull back the liner to locate them. The bolts/nuts are often rusted and care need to be taken removing the nuts or the whole thing will just revolve in the plastic.
Offline garethwd
Re: Silly question.
« Reply #2 on: February 21, 2026, 08:56:38 AM »
Sounds like a great deal of fun🤣... Ok thanks, I didn't want to start pulling on something that shouldn't be pulled off. I will give it a go.. Thank you
Re: Silly question.
« Reply #4 on: February 21, 2026, 11:04:09 AM »
look at that, how to do it and an incentive not to break the current one in one post  8)
Offline garethwd
Re: Silly question.
« Reply #5 on: February 21, 2026, 02:53:00 PM »
Wasn't needed in the end. I've been cleaning earths and connecters and hey presto. 🥳
