Author Topic: Shifter rod adjusting rod nut  (Read 569 times)
Offline Joe912/62
  • Country: ca
« on: February 21, 2026, 06:49:00 PM »
Should there be another nut under the bracket to lock
the top nut when adjusting the rod? The parts diagram shows one but
I had another nut under the bracket also.
Offline Joe912/62
  • Country: ca
Re: Shifter rod adjusting rod nut
« Reply #1 on: February 21, 2026, 06:50:10 PM »
Updated photo
« Reply #2 on: February 21, 2026, 09:18:01 PM »
Joe,
Two nuts are sufficient, one above and one below.
It's likely there may have been a wavey washer or two involved from
the factory, mostly long gone and not essential.
Offline Joe912/62
  • Country: ca
« Reply #3 on: February 22, 2026, 11:23:41 AM »
Thanks Nigel
