Author Topic: Shifter knob  (Read 47968 times)
Offline Joe912/62
  • Country: ca
Shifter knob
« on: February 25, 2026, 09:48:57 PM »
What’s the thread on the shifter M10x1.0?
I would like to replace it with something a bit nicer
Offline George-S
Re: Shifter knob
« Reply #1 on: February 25, 2026, 10:04:00 PM »
Yea its
M10 1.0
Offline Joe912/62
  • Country: ca
Re: Shifter knob
« Reply #2 on: February 25, 2026, 11:32:33 PM »
What are my options for replacement?
Re: Shifter knob
« Reply #3 on: February 26, 2026, 10:23:21 PM »
I've got a wooden knob that my father turned on his lathe
many years ago which fitted on something I was driving back then.
I modified it later to have an 8mm side grub screw, also bored out the centre
to, I think, around 10mm.
I like the personal custom concept , so if you have a friend with a lathe or a local engineering shop
you could have a wood/aluminium/plastic thingy made up to suit.
Alu is a bit touch-cold though, depending on your climate!
Options are endless fun.
Re: Shifter knob
« Reply #4 on: February 26, 2026, 11:22:52 PM »
 ;D
Re: Shifter knob
« Reply #5 on: February 27, 2026, 08:34:33 AM »
I have a spare pre facelift knob which I refurbished a while ago. Probably need to replace the bush as I think thread is different.
Re: Shifter knob
« Reply #6 on: February 28, 2026, 09:40:24 AM »
If you use the Nardi or Momo 3 grub screw approach you have 100s of interesting choices and you can shorten the lever if you wish. I think from memory I cut off the thread when fitting the short shift kit from Beta Boyz and fitting a Nardi gear knob. It will be in the pictures of my car in Members Cars.
Re: Shifter knob
« Reply #7 on: February 28, 2026, 09:15:42 PM »
Came with my car.  I will let you know if I like it when I get to drive it in the Summer/Winter
Offline Joe912/62
  • Country: ca
Re: Shifter knob
« Reply #8 on: March 02, 2026, 11:47:36 AM »
Looks nice
Re: Shifter knob
« Reply #9 on: March 05, 2026, 11:47:46 PM »
Quick-shift kit fitted tonight ready to go in :-)
