Author Topic: rear window heater Beta Berlina 2000 1979.  (Read 5026 times)
Offline Don Pedro
  • Country: nl
« on: April 22, 2026, 10:42:34 AM »
How is the exact working of the rear window heater switch? When switching on the ignition (no start) it is ready to work or only by running the car?
Re: rear window heater Beta Berlina 2000 1979.
« Reply #1 on: April 23, 2026, 10:55:27 AM »
Should work just on the ignition?
« Reply #2 on: April 23, 2026, 10:22:19 PM »
I agree with Neil.
Remember that with the engine running it will be more effective as the voltage
is up around 13.5/14v.
I can't recall if this is wired through a relay. If not, this could be
a sensible addition.
Offline neromoto
« Reply #3 on: April 24, 2026, 04:11:38 AM »
I haven’t actually checked the circuit diagram for the Berlina 2000 1979, but the circuit for the rear window heater should be the same as that for the cigarette lighter in both the early and late models of the Beta.
How about checking whether there is a 12V supply to the cigarette lighter?
If there is no power, it is likely that the relay is faulty.
Masataka
« Last Edit: April 24, 2026, 04:18:01 AM by neromoto »
Thema 8.32 S2 1990
Gamma Berlina S1 1978
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
Offline Don Pedro
  • Country: nl
« Reply #4 on: April 24, 2026, 08:55:23 PM »
Masataka
Thanks will check this....
