Author Topic: HPE added to my Lancia family  (Read 24097 times)
Offline deks
  • Steve Hudson
Re: HPE added to my Lancia family
« Reply #40 on: September 30, 2026, 10:01:38 PM »
Steve,
Just seen your car in Ian's (hubnut) video of Rustival.
Shame he didn't mention it, just walked past it!
Hope you had a good drive back.
got a mention here 7.20m
https://youtu.be/i3VXoAUo7Vw?si=XjbSfOTn5qHCG2Mh
Offline deks
  • Steve Hudson
« Reply #41 on: November 11, 2026, 06:50:27 PM »
In the summer when changing the fuel pipes an eagle eyed member spotted some crusty metal on the offside rear turret. I missed this at the time but knew over the winter it would be on my list of jobs to do so this week I have embarked on the strip out to do this job.
I am also going top replace the front calipers with freshly refurbed ones a friend has done for me
retrim the door cards I am going to try a cheap fix first and if not happy will have them redone to match the seats which aren't original
I also need to sort the gear linkage out as its awfully difficult to select some gears
I also want to change the ignition key/barrel as my understanding is this is the route of a power problem and the reason a by pass system has been put in
Offline deks
  • Steve Hudson
« Reply #42 on: November 13, 2026, 01:39:22 PM »
Its like deja vu   :D :D
So Ive made a start on the turrets I say plural as I thought I'd better scrub the sound deadening off on the nearside that looked fine. Turns out it's worse than the driverside. Thankfully it's nowhere near as bad as the Spyder was and hopefully a fairly simple repair. Wasn't expecting to have to do such work but she is 44 years old and as far as I can work out its been at least 15 years since she last had any work and even then its unknown what was done, The previous owner did make enquiries to find out but the info requested was never sent.
  As advised better to find it now and deal with it before it spreads and gets a lot worse.
One bit thats a tad annoying it is what I found on the C pillar, I knew there was a tiny rust hole which I intended to drill out and grommet due to location but I found a chunk of filler behind it hence the oblong hole now and welding hear worries me as its mighty close to rear quarter and I don't want to damage the paintwork.
This work and the planned stuff will keep me busy over the winter though
« Reply #43 on: November 14, 2026, 04:03:53 PM »
Have a look at Frost Restoration For Heat Block Paste to repair that area close to paint you want to protect. The rear turrets are bobby trapped by the rectangular inserts fitted with no edge sealant creating a perfect water and rust trap. Every Beta can have this fix needed.
Offline deks
  • Steve Hudson
« Reply #44 on: November 15, 2026, 10:44:26 AM »
Thank you for this info. I never knew such a stuff existed. I couldn't find any on Frosts website, maybe I used the wrong term of description but found some on Amazon that I have ordered.
Offline deks
  • Steve Hudson
« Reply #45 on: November 15, 2026, 05:41:59 PM »
Had a bit of time in the garage today. Stuart came over to collect his wings so I did some small jobs to keep me busy while I waited for him.
My drivers door drops when opening so so made use of a jack today to lift it slightly then loosened and retightened the hinges brackets to achieve a good fit. I've tried to adjust it before but without the use of the jack and its seemed fine until i drop the car back onto four wheels. Also noticed it to be not so present with the door cards off so I wont really know for a month or two when I put the car back on the ground and refit the door cards.
Ive also today sprayed the inside of the doors and rear quarters with some cavity wax as recommended by a trusted friend.
Ive done some of the chassis rails and will do the rest this coming week.
While I am sorting the welding out and during this winter period while it's stripped at the rear end I will dismantle the rear subframe and clean and paint it and the arms and the rear hubs.  I ve just ordered Goodrich braided hoses all round. i might even strip the rear struts and springs and give them a coat of paint.
« Reply #46 on: November 15, 2026, 10:05:29 PM »
Hi Steve,
Good to meet you this weekend.
The hpe body is quite flexible. My doors don't fit when I've jacked one end!
Best to do door adjustments on 4 wheels, and ignore when not.
Offline deks
  • Steve Hudson
« Reply #47 on: November 21, 2026, 05:54:09 PM »
so winter is here, first job to tackle is the presence of some unwanted rust in serval places as to be expected with a 45 year old car.
Offline deks
  • Steve Hudson
« Reply #48 on: November 23, 2026, 07:03:44 PM »
So today I tackled the C pillar inside the boot closure. Sorry forgot to get a pic of the repair here.
I was also aware of the trailing side of the nearest rear arch being suspect, spotted in when I did the rear brake in May but as I am here best to sort it.
Turned out a little worse than I anticipated and also along the sill footwell join a bit.
Happy with the repair here and will get it painted up.
I also have to repair the bracket on the bumper side mount. I was nervous welding this due to it being chrome and although this doesn't concern me not the rubber bottom half does. I took the bumper off but haven't yet got to look at repairing it yet
« Reply #49 on: November 23, 2026, 08:33:31 PM »
Hi Steve
There is no chrome, all stainless in the bumper.
Offline deks
  • Steve Hudson
« Reply #50 on: November 23, 2026, 09:30:19 PM »
Hi Steve
thank you Peter, that I am feeling makes for an easier repair of the bracket thats come adrift
« Reply #51 on: November 23, 2026, 09:57:22 PM »
I should have added the brackets are ordinary steel.
