Author Topic: Gear linkage adjustment  (Read 11489 times)
Offline Dynomax
« on: August 19, 2026, 09:11:11 AM »
I've just got my engine and gearbox back in and the gear linkage adjustment is driving me mad. It seems no matter where I have the adjustment of the front rod I just cannot get enough side to side movement to get 5th and reverse. The problem is when I dropped the subframe with the engine it got a bit out of control and I'm not sure if anything got bent or strained, on top of that I had the gearlever out to put a slight bend in it (bring it closer to me) and when I was reassembling it was in a bit of doubt about the order of parts. I've taken some pictures of where I think the problem might be but of course no idea how to post them.
Any suggestions would be very welcome.
Re: Gear linkage adjustment
« Reply #1 on: August 19, 2026, 10:16:24 AM »
The easiest way to attach pictures is to host them on a site like Flickr and then post the links here. The links will look something like {IMG} link here {/IMG} except with square brackets not curly. YOu can also use the 'Attachments and other options'  button below the message box.
« Reply #2 on: August 19, 2026, 02:19:35 PM »
Re: photo att.  I use my iPhone mail app to send photo's to myself and it gives me the option to make smaller (which you need to do most likely) and then edit-rotate 90-save and do it again rotating straight again and this stops the photo's being squished
Re: gear change - I replaced all the bushes (baring to bell-crank bush under the rack, as at the time I couldn't get to it)  and I found the same as you.  I found a really old post on this site that suggested a couple washers in the front left side of the gear change mounting, inside the car (under the heater).  and bingo it did the trick.  Since then I have replaced the final bush, and have a spare if you need it shout.  Now everything is all good.  Best thing about my car is the gear shift :-)
Oh PS I also did Betaboys quick shift conversion
Offline Dynomax
« Reply #3 on: August 20, 2026, 06:04:38 PM »
This is the first chance I've had to reply. I have got all the gears now but I do suspect that something got either strained or bent as I've got the front rod on the shortest adjustment It has and I have replaced the cross rod with Mark's replacement but I've had to adjust the length about 3mm longer. It now changes with a real positive movement compared to the original.
Thanks for the advice/suggestions.
« Reply #4 on: August 20, 2026, 09:49:14 PM »
What state is the bush in the front vertical rod like? It’s hidden behind a washer so seeing it will require a nut removing! If that’s worn (or missing) it’s going to make selection hard.
