Author Topic: Non -starter for 10  (Read 9482 times)
Offline Betared
Non -starter for 10
« on: August 20, 2026, 10:19:57 AM »
Hopefully the forum can save my sanity. The main problem is non starting of my Beta 2000,1984 with electronic ignition.
I have fuel supply to the carb and the return to tank is clear.When I crank the engine with my strobe light connected to each plug in turn it flashes, indicating a spark? Two things which may be related while I have been checking are the ignition light has disappeared at swith on and there is no 12v supply to the shut off solenoid valve, I have rigged up a temp. supply from the battery to keep valve open.Where does the supply to this connection originate? Any thoughts anyone.
David.
Offline lancialulu
Re: Non -starter for 10
« Reply #1 on: August 20, 2026, 10:32:14 AM »
Stuck needle valve? Take air cleaner off and look int carb and rapidly operate the throttle by hand you should see jets of fuel from the accelerator pump if fuel is in carb. However your lights situation suggests something else and not sure what that could be.
« Reply #2 on: August 20, 2026, 10:58:52 AM »
First check all fuses, sounds like either fuse or you have an ignition barrel issue if you do not have the dash light. The wiring diagrams in the downloads section should hopefully be able to help you trace it through.
Odd if you have fuel and spark however it does not at least try to fire, though pumping the accelerator a few times should give you enough fuel via the accelerator pump in the carb to do something.
« Reply #3 on: August 20, 2026, 11:53:08 AM »
84?  Is it Injection?  sorry just read again, its carb...  Ignore me
Offline deks
  • Steve Hudson
« Reply #4 on: August 20, 2026, 03:55:17 PM »
I am inclined to be with Peter on this. I have a dodgy ignition barrel on my HPE which has had some kind of wiring modification to a switch which I have to use at times to give a feed to ignition lights in order for the car to start. I have a new ignition barrel to fit but I need to understand the wiring modification first which apparently is on a forum somewhere as the person i got the car from advised me this is where he copied it from to install as I want to undo that.
« Reply #5 on: August 20, 2026, 08:56:04 PM »
Hi David,
Have you put the engine at TDC and then checked the position of the rotor arm?
It must point to lead #4.
If not, swop leads around or better, remove distributor and turn it to point
correctly.
Offline Betared
« Reply #6 on: August 20, 2026, 09:13:59 PM »
Thanks for the info. I'm confident fuel is going to the cylinders, as I am cranking for a bit longer than normal to try and fire up when I look at the plugs they are wet. Fuses all check out.
Looking at other posts I am wondering if my spark is as good as it should be, I have a CAMBIARE coil ref. VE520011 fitted which according to their site isn't correct.They recommend the VE520004 but I can't find the difference between them.Anyone used these coils? Will look at the ignition barrel on Saturday for loose wires.Anyone know where the wiring diagram is to be found?
Nigel, I have checked timing according yo the post elsewhere on this forum where #4 cylinder is used for timing but I assume that the plug leads are connected 1,3,4,2 with #1 nearest the cams?
« Reply #7 on: August 20, 2026, 09:58:02 PM »
Yes David,
#1 is cam wheel end.
