Author Topic: removing door window trim...  (Read 12100 times)
Offline Ryan
« on: August 27, 2026, 10:43:50 PM »
How does one remove the chrome trim with the rubber wiper at the bottom of the door windows?
thanks for any help
Offline Ryan
Re: removing door window trim...
« Reply #1 on: August 27, 2026, 10:52:33 PM »
I just read a few posts below, I think someone answered my question.  I guess the trim is welded onto the inside of the door?  Can I remove it without taking the window out?
« Reply #2 on: August 27, 2026, 11:13:11 PM »
Both the inner and outer window scraper are attached to the stainless trimwhich run the full length of the door, ie at the bottom of the window and the small triangular window. They are both simply held i by friction ie the stainless trim is an inverted U shape over the edge of the door and you just carefully need to pull it upwards to remove it. Then when both are removed you can remove the window glass.
