Author Topic: An enjoyable Coupé restoration film.  (Read 366 times)
Offline Sandro
« on: November 16, 2026, 08:28:05 PM »
I hope the link works!
enjoy,
https://www.youtube.com/watch?v=mSbp--pWGzc
A.
1972 Honda cub
1984 Silver 2000i HPE
2005 Opel Vectra ( everyday )
Re: An enjoyable Coupé restoration film.
« Reply #1 on: November 16, 2026, 10:18:13 PM »
A typical made-for-tv doc, nevertheless a good film.
Some missing footage here and there but yes, enjoyable.
And always good to have Beta's in the media.
« Reply #2 on: November 17, 2026, 04:41:19 PM »
I think I might have mentioned on the other thread on the same subject, I am sure this car was on someone elses stand at the March 2026 Restoration Show?  I had a good look underneath but never got chance to look under the bonnet
« Reply #3 on: November 17, 2026, 05:18:53 PM »
Yes, it was on a stand at the Restoration Show and we had a good look at it. Looked tidy but there were a couple of details like a missing sunroof seal....
« Reply #4 on: November 17, 2026, 05:50:32 PM »
The owner came to our stand at the NEC on Friday for a chat. A lovely guy we pointed at Beta Boyz parts so hopefully he can get the missing seal.
« Reply #5 on: November 20, 2026, 04:31:48 PM »
or cut it out and put a full length Webasto roof in  8)
« Reply #6 on: November 20, 2026, 04:59:52 PM »
A Webasto in a roof in a car with an existing sunroof is problematic as there's a steel cassette welded into the roof to accommodate the sliding panel. Or corroded to buggery in my case... I think removal of that structure would complicate the fitting of an alternative and it's simpler to replace the original seal. That didn't seal very well...
« Reply #7 on: November 20, 2026, 09:18:57 PM »
Personally my heart sinks when I see a webasto on a Beta 😂 they are for MGBs and the like. I think a fully functional steel roof is better or even better no sunroof at all and less rust!
« Reply #8 on: November 20, 2026, 11:49:39 PM »
Any car I had with a Webasto was the best, loved them.  I had two Berlina's with a full length sunroof and a MGBGT
Offline Sandro
« Reply #9 on: November 21, 2026, 09:36:57 AM »
Please forgive me for straying off topic here but speaking of sunroofs ( and I refer to my 'to do list' ) mine doesn't want to retract up into it's 'original' position on closing without a gentle push from beneath before I engage the 'locking' mechanisim. It's a factory sunroof by the way. Some inital research indicates that it maybe worn cams ? I have found a post on here about Sunroof removal which is useful, but nothing that specifically relates to this ( I might have missed it ) Is there anyone here who has carried out this operation to replace these Cams, and how easy are they to find?
With thanks, and best Regards Andrew.
1972 Honda cub
« Reply #10 on: November 21, 2026, 10:10:42 AM »
Sunroof - removal wasn't too difficult following the instructions I found on here. Once it was out I took the parts off and gave them to Mark (although they are tiny so he may not know where he put them 18 months ago, and I can't remember how worn they were). I can't recall if the cams came off the actuating rods easily or at all but they're nylon/plastic so must be printable now with the right materials? Back in the day my two VX HPE's had sunroofs and I was aware of the potential weakness in these parts so got into the habit of closing the roof and lifting the back edge before closing the handle to take the strain off these parts.
Offline Sandro
« Reply #11 on: November 21, 2026, 01:10:11 PM »
Thank you for your reply, why did you remove your sunroof ? 'Yes' I'm always quite careful opening or closing the sunroof. Thanks I'll contact Mark about the parts I may need. Busy with Headlamp replacements on the Opel at the moment.
1972 Honda cub
« Reply #12 on: November 21, 2026, 03:57:52 PM »
The sunroof was removed because they can leak and cause heavy corrosion especially in the receiving (poorly protected) cassette and the pipework where it joins the plastic drain tubes. If they fail then the water will wreck the interior trim. They can also cause wind noise. On my car the corrosion was on the verge of rotting out the roof above the rear screen and the cassette needed a lot of repair work. Given my preference for a non sunroof car it was easier to get a roof cut and stitch it into the old roof. The original headlining was also damaged where the visors had been ripped out (not by me) so it needed remaking. Luckily the roof cut came with the tensioning bows and a rough headliner I could use as a pattern which allowed me make a new one in black Alcantara. My car is never going to be a factory concours one, it's more of a resto mod!
Offline Sandro
« Reply #13 on: November 23, 2026, 07:13:24 AM »
Nice, thanks for the background. I imagine it would've required a decent body shop to stitch that roof section in seamlessly.
I enjoy my 'open-roof' its almost always open when I take it out. ( summer only )
A.
1972 Honda cub
« Reply #14 on: November 23, 2026, 08:45:39 AM »
There's a whole thread on in the Members Cars area - titled "And So It Begins". It's rather a long read and now I'm almost back up and running again myself I'm hoping to progress it soon!
« Reply #15 on: November 23, 2026, 08:46:10 AM »
I might regret saying this but my very rusty VX has no obvious rust in the sunroof. I haven't stripped any paint off it though.....
« Reply #16 on: November 23, 2026, 04:49:52 PM »
The roof itself should be okay, it's the frame it slides into and the tubes in each corner. They're not painted (maybe a light dusting) and moisture gets to them. The only way to check is removal of the headliner. Hope there are no horrors. It's a pig to put right!
« Reply #17 on: November 23, 2026, 05:38:19 PM »
Well there's not much chance that I'll even get around to getting it back on the road but I can say that the sunroof functions correctly if nothing else! I don't think I'll get into it that deeply
