Author Topic: Getting wax inside the A pillars?  (Read 30 times)
1 Member and 1 Guest are viewing this topic.
« on: November 22, 2026, 09:56:16 PM »
If I was going to get wax inside the A pillar, how/where best to stick my lance?   Any tips
Re: Getting wax inside the A pillars?
« Reply #1 on: Today at 09:02:14 AM »
Access from either above or below. I'd be careful with access from either end with the headliner in place though as overspray could ruin it. Removal is straight forward though if you don't have a sunroof. Unscrew and remove the two visors and clips, remove the mirror and screw it's mount. Remove the light cover and unscrew the light body and photograph the connections so it goes back the right way eventually. Remove the grab handle (2 screws). Remove the door seals and peel the headliner off the flange. Remove the plastic strip at the front of the car that grips the headliner near the screen and peel the liner off the bracket it was clamped to. The front of the headliner should drop down exposing two metal strips , push these up to rotate the first headliner cross through 180 degrees. Then you cn gently bend the sprung steel rib so one end can be popped out of the plastic socket and the other side slid out. This will give you safe access for the lance from above. It'll also expose the box sections that run backwards above the doors and side windows. If you want to treat these you'll have to remove the side windows, the seals and peel the headliner off before removing the last 2 bows and dropping the headliner back down. Slight word of warning! If you're doing that then plastic sheeting everywhere to protect the trim. There are holes in the A pillar that may allow fluid through. They may be taped over but accessing them requires the trim down the A pillar to come off and that means windscreen out I think. If you do it with then in situ then any excess fluid will probably run down the side of the car where the door bins are. If you haven't already removed those to rustproof there's great access to the inside go the A Post.
Lots of work, best done with warm fluid on a cold day so it stops running quicker!
Good luck!
« Reply #2 on: Today at 12:23:08 PM »
Thanks Guy.  This looks harder than I would have thought.  I will aim to get to everything in the next few months.  I have done the obvious so far
