Author Topic: Strut Braces  (Read 132 times)
Strut Braces
« on: November 23, 2026, 05:01:09 PM »
Some of us spotted an advert on Facebook for the brackets to make a front strut brace. Laser cut and welded together. I noticed a few familiar names on the list and a conversation with the seller ensued! So, Peter (Stokes) has bought one pair and Mark Wastnidge another. I've collected the remaining four pairs for myself, Chris Mace, Nigel and Alex. The plan in the next few days is to order material to make the bar itself which will be 2 Rose Joints (Left & Right handed) plus weldable threaded bosses and some matching tube. Once the batch is made I'll have them powder coated satin black.
Three of us also wanted to look into a rear strut brace and the brackets will fit the rears as well but there aren't enough in this first batch. Mark Ferris has also asked for a pair so I've asked the seller to see if he can retrieve his CAD drawing and put another 6 pairs together for me. I have zero clue as to costs at this point but the pairs are working out at £70 each before the rest of the parts are bought, welded and powder coated.
If I get more made then they'll be available at cost plus shipping. Photos to follow in the next week or so. I may get back to my own car soon....
Re: Strut Braces
« Reply #1 on: November 23, 2026, 09:45:27 PM »
Nice idea but a standard volumex might pose problems.... (expansion tank and air box??)
Re: Strut Braces
« Reply #2 on: November 24, 2026, 08:58:12 AM »
Hi Tim, yes, we've spotted the expansion tank issue, it'll need dropping a little and I'm not 100% sure that's feasible yet. A straight bar passes right over the cap. I've got the chaps checking on the standard air filter housing (any pipework for hot air from the exhaust manifold might have to be looked at) but the injection and VX airboxes are probably too much of an interference fit. Can you run a string between the strut towers (underneath the strut braces) and measure the gap underneath that and the top of the airbox?
The plan to use Rose Joints at both ends with shoulder bolts may need a slight modification if the expansion tank drop is possible, I'm thinking a pip pin for ease of access on the left side of the car now.
Re: Strut Braces
« Reply #3 on: November 24, 2026, 09:39:38 AM »
My air box may not be fitted for a few days.... Looking at photos it should pass but close and not convenient for changing plugs etc....
Tim
Re: Strut Braces
« Reply #4 on: November 24, 2026, 11:52:28 AM »
Looking at photos I suspect the VX/iE air filter is lower than the projected positioning and the standard air filter is far enough forward. It's also possible that the later expansion tank would be less likely to interfere with the brace and still allow radiator cap removal without moving the bar. Shame I don't have a later expansion bottle to check! Looking forward to getting the dimensions checked.
Re: Strut Braces
« Reply #5 on: November 27, 2026, 08:36:19 PM »
In anticipation of the new fitment, I've replaced the top mounting studs
with 20mm versions.
Removing the old was easy with the press and a suitable socket underneath.
These are stainless, not the best material, but I didn't want to wait
for a China delivery. (I've since found that my supplier, PG Merlin, does have
copper-coated carbon steel studs)
I test fitted with a nut on each, all good, then welded them in.
Happy with the result. Doesn't look like I'll get back on it until
Sunday with rain tomorrow.
As it happens, it appears that I'll have to lower or move
back my expansion tank but that will wait until I've got the brace.
Re: Strut Braces
« Reply #6 on: November 27, 2026, 08:52:00 PM »
Slight supplier cock up! The Rose joints and locknuts are M12*1.5 as ordered. The 20mm M12 bushes, confirmed as 1.5 dropped through the letter box today as M12*1.75. Replacement ones on the way. Tubes on the way next week so I may get everything welded up at the end of next week and off doe powder coating after a trial fit!
Then I'll be waiting for another batch of top mounts before the rear bar design can be implemented!
