Author Topic: Dashboard Removal - 1983 Beta Coupe  (Read 43 times)
Offline Palikary
  • Country: au
« on: November 26, 2026, 10:44:13 AM »
Im trying to remove the dashboard to access and repair the heater/ac matrix box which was disconnected when I bought the 1983 Beta Coupe.
I have removed I believe all the screws and the dash is moving and ready to come out except it’s still connected by the windscreen air vents which are attached to the bottom of the dash by screws and the other end sits inside the top of the air box. I started removing the top screws of the air vents under the dash and then noticed there are screws behind also on the firewall side which are nearly impossible to get to so im assuming that that’s not the right to take it out. Did I miss a screw or is there a certain way to pull the windscreen vents withe the attached dash away from the airbox? I did not want to force it up unless I was certain there was nothing else holding it in. There is one bolt after I removed the centre air vents which seams to control the vent flap which I didn’t remove as I didn’t think that was holding those vents down. If anyone has been here I need so advice on how to release this dash please.
Online SanRemo78
Re: Dashboard Removal - 1983 Beta Coupe
« Reply #1 on: November 26, 2026, 11:57:50 AM »
There are 5 main fixing points, three at the top. One behind the instruments, one behind the radio and one behind the glovebox (accessed through a removable cover within the glovebox. There are two further screw fixings bottom left and right underneath square plastic plugs that lever out. There are two further screw fixings fixing on top of the steering column visible when the gauges are out and another on a support bracket in the passenger footwell attached to the brake pivot assembly housing cover on RHD cars. With the instruments removed and the radio out of the way the heater controls should unscrew and can be left in place. You'll already have removed the fragile plastic lower shrouds underneath the dash either side as they're screwed into the heater box but I can't think of anything else retaining the dash. Shout if you need more photos - mine is currently out of the car! And I don't recognize the bolt in the lower picture as being part of the dashboard securing system 0 but I could be wrong!
« Last Edit: November 26, 2026, 12:05:07 PM by SanRemo78 »
Online SanRemo78
« Reply #2 on: November 26, 2026, 12:12:38 PM »
And it is possible to remove the heater box without removing the dashboard.... If you remove the centre console by undoing the seat belt bolts at the back, two screws either side of the handbrake, the upper console (couple of fir tree fixings and two screws - don't drop the plate nuts!) and lift it out you can unscrew the drain pipe's jubilee clip, plus the two heater hoses on the side (bucket handy!) then the four nuts around the vent flap in the scuttle and it should drop out with the heater controls attached once you've disconnected any electrical connections to that assembly. The halves of the heater box are held together with steel snap clips that lever off easily enough but can fly off never to be seen again if you're not careful! After that it all comes apart pretty simply. There's an electrical connection to the fans to disconnect but if you've got air con in the car you might want to get that professionally degassed before going any further!
Offline Palikary
  • Country: au
« Reply #3 on: November 26, 2026, 11:36:08 PM »
Thanks for your reply. I have all the interior out of the car as well as the center console. So I'm free to do and try anything.
Can you send me a photo of the dash already removed and are the windscreen plastic vents still attached to the dash when it comes out? I want to see the bottom of the vents that go into airbox what shape they have so I know how to try and pull them off the airbox side. Maybe they used glue around the sponge when inserted inside and i need to use more upward force to separate it.
Online SanRemo78
« Reply #4 on: Today at 11:14:27 AM »
Right, if I've got the photos in the correct order...
These show the ight main captive bolt on the right side the bulkhead underneath the windscreen plus the lower one by the door and two on the steering column.
Next are the left side, windscreen, left lower and the bracket on the brake pivot in the passenger footwell.
Third picture shows the heater box in situ with a small white fixing visible above the coiled up wiring. There's a screw or bolt through this that will need to be undone to remove the dash.
The dash comes out with all the air vent tubing in place.
« Last Edit: Today at 11:19:43 AM by SanRemo78 »
