Author Topic: what is this?  (Read 72 times)
Offline deks
  • Steve Hudson
what is this?
« on: November 26, 2026, 03:28:35 PM »
Hi guys while cleaning the anti roll bar under my HPE I've cut through the pipe to this device which is attached the the rear subframe which is currently removed from car. I believe this is possibly the device that operates the self levelling headlights. I am unsure whether it works or not or even how to really test it. The headlights are not the best and they are very low and close to the car so I suspect possibly it doesnt. If this device is for that it certainly wont work currently as I cut through the pipe. I have got so parts to repair it but want to know what operates it and if I can top it up and does it require so form of bleeding etc etc
All advice welcome
Offline deks
  • Steve Hudson
Re: what is this?
« Reply #1 on: November 26, 2026, 06:21:58 PM »
Got to love google. Ive answered this myself with tracing the pipe and then google. Even offers advice on how to refill and bleed it but does also suggest it's usually pretty fruitless as the seals are usually shot. Will give it ago
Offline Sandro
Re: what is this?
« Reply #2 on: November 26, 2026, 07:22:54 PM »
so 'does it' operate the self levelling headlights?
A.
1972 Honda cub
1984 Silver 2000i HPE
2005 Opel Vectra ( everyday )
Offline deks
  • Steve Hudson
Re: what is this?
« Reply #3 on: November 26, 2026, 07:29:41 PM »
A.
It is supposed to, whether it actually works or not remains to be discovered
Re: what is this?
« Reply #4 on: November 26, 2026, 10:22:20 PM »
The HPE headlight level system is a sealed unit and was available from
factory as a complete item that could be installed as such.
Unfortunately, if the hydraulic containment is breached it becomes a brick.
There is no factory or service manual way to recharge it. That doesn't mean it's
impossible though.
If you are handy with hydraulics and can find pipe connectors and a suitable
charge valve, it may be possible. The fluid is an unknown to me.
In my case, it wasn't working when I acquired my car,so I removed the entire system.
I then fixed the lamp actuators in a suitable position to retain ability to align.
Offline deks
  • Steve Hudson
Re: what is this?
« Reply #5 on: November 26, 2026, 10:39:34 PM »
impossible though.
google suggest  antifreeze mix or methylated spirit mix is what's needed and immersed in fluid and bled by pumping valve may fix. it does caution though that seals are known too deteriorate and aren't replaceable. weirdly when moving the valve under the bonnet on the passenger side i could clearly see the headlight on the drivers side moving as well.  Ive got nothing to lose giving it a go so I shall. if it doesnt work Ill be enquiring about how to fix it in place but adjustable without the need for new headlights( I sold the Spyder ones last week )
Re: what is this?
« Reply #6 on: November 27, 2026, 01:08:39 PM »
Hi Steve
Should be pretty simple to fix.
The lights are fixed to the backing plate via two screw adjustable bolts at the lower part of the light and there is one which attached from the top of the light to the levelling system. You may find with no fluid in the levelling system the attachment is solid and not move anyway, but you could replace it with a fabricated bracket with a slots and hence make it adjustable.
