Author Topic: Intake ports and valves....  (Read 7390 times)
Offline hongkongphooey
« on: February 17, 2010, 09:58:35 PM »
As a matter of interest,how finished are the standard intake ports in the head,and do the valves have slightly wasted stems?
I ask because i've had the intake manifold off and the ports look like they've had work and the intake valve stems are slightly wasted.
Re: Intake ports and valves....
« Reply #1 on: February 21, 2010, 10:15:55 AM »
Has nobody had a head apart then?  ???
Offline 75coupe
  • 1975 Beta coupe 2L
« Reply #2 on: February 21, 2010, 10:29:55 AM »
I have had a few heads apart, and can tell you that the stems are not normally wasted. The port finish is a cast finish with a line (casting mark ) running through the centre line of the port where the sand cast forms meet. Are the valve guides still protruding through into the port? Do you have a pic? I'll see if I can take a pic of a std head.
Offline 75coupe
« Reply #3 on: February 21, 2010, 11:05:04 AM »
Sorry I got that wrong, the inlets are very slightly wasted stems, just below the guide......
« Reply #4 on: February 21, 2010, 04:41:52 PM »
Yeah that sounds about like mine....the ports however don't have any casting lines,just fine circular lines that look like they have been made by a flap wheel or something. The guides have not been touched by the looks of things.
« Reply #5 on: March 10, 2010, 06:43:55 PM »
Hong Kong
Have a look at Guy Croft Racing Engines website there are lots of pictures of tuned and ported components so you will be able to spot 3 angle valve seats and real performance cams.
« Reply #6 on: March 11, 2010, 07:50:26 AM »
Thanks Eric....i'll do that.
