Author Topic: Inlet & Outlet pipes  (Read 14341 times)
Re: Inlet & Outlet pipes
« Reply #20 on: September 28, 2026, 12:34:11 AM »
I have a similar problem on a carb. I want to overhaul as a spare in that the return pipe has been broken flush with the carb. top. I have managed to carefully drill out the remaining stub and am left with a 6.5mm  diameter hole.There is enough metal to drill out to 9mm dia and use the fitting as described but what I have noticed is the original pipes internal diameter has a restriction in it, I have managed to get a 1mm drill in it.Presumably this has been done to restrict the fuel flow from the float chamber? Has the above modification been tried successfully?
found this one with the restriction fitted
https://ebay.io/m/JqpsyT
« Reply #21 on: October 03, 2026, 12:45:41 PM »
I had a very useful conversation with a guy from Webcon on the subject.  They are just around the corner from me so I popped in.  He gave me a few unions to try.  I have ordered the taps and will give it go tomorrow.  I dont see I have much to loose so worth a go.
He recommended Loctite 542 to seal threads and they use a small jet in the return union to maintain the c0.7~0.9mm restriction.  I will post pictures after I have completed the task :-)
Offline Betared
« Reply #22 on: October 05, 2026, 10:59:28 PM »
Thats a good find with the restriction included. I am going to try some body filler in the threaded end and then drill out at 1mm dia.Can someone advise how to attach photos to a post,I'm not having much luck.
Doh! After posting the above and going back I see my photo attachment? anyway it shows my modified outlet connection fitted with a fibre washer.The inlet is still secure.
« Last Edit: October 06, 2026, 10:59:16 AM by Betared »
« Reply #23 on: October 06, 2026, 11:20:50 AM »
I would not use body filler on anything near fuel.
Araldite, JB weld or similar would be more appropriate.
« Reply #24 on: October 06, 2026, 05:45:28 PM »
I can confirm JB weld was good for a few months but then went soft and leaked.  A Google says JB Weld does not like Ethanol, of course I couldnt find that when I first used it :-/
I did use JB Tank Weld for Betameeta and it was rock solid when I removed it last week.  New Pillar drill just turned up so I might get to start on this tonight
« Reply #25 on: October 10, 2026, 12:01:53 AM »
Right-o Pillar Drill turned up.  Pulled the old unions out eventually.  A bit of head scratching how I hold a carb top in the right position to drill straight.  I made a holder in timber and used the airfilter fixings inserted into the timber and then held in a vice.  Seemed to do the trick.
Smaller Return union was m8x1.0 and I turned down the 0.7mm jet and drilled out the top of the union and screwed it in as Webcon man said to do.  The second Feed union, as I was told, and a quick look with pitch gauge I thought it was m10x 1.0.  So drilled and tapped away, only to find out it was in fact 0.9 pitch which is a pitch that carb companies sometimes use.  Ordered the right thread 1.0x 8mm Feed union.  Its is a little short really but will test tomorrow and hopefully okay for a 20 min journey to Brooklands on Sunday.  If is rubbish I can order some better item I have now found at Eurocarbs.  Fingers crossed this has worked.
Everything super sealed everything with blue paper and masking tape before I started drilling, and super cleaned out after with brake cleaner.  Then fuel union/s threads sealed up with Loctite 542 as I was recommended.  Test tomorrow.
PS a 4.5mm drill bit fits in the filter housing supply to the float needle (again Webcon man recommendation)
« Reply #26 on: October 10, 2026, 03:53:19 PM »
Hi Mark
Looking really good!
« Reply #27 on: October 10, 2026, 09:36:22 PM »
tested today close to home and so far zero leaks.  Brooklands Motorsport event tomorrow which is <30 mins away so a better test.  Airfilter stud pulled  :-X
