Author Topic: HPE HEATER CABLE  (Read 4526 times)
Offline spud
HPE HEATER CABLE
« on: October 06, 2010, 09:51:14 AM »
Hi all,
My previous post on interior trim bits generated zero replies :( so I don't hold out much hope on this one but...
The pic in the link below shows the end of my heater control cable. This is located on the right hand side of the centre console, to the left of your shins if you were sat in the drivers seat of a right hand drive car. This is the other end of the cable that has the red square/blue square icons on the slider. It is meant to connect to the lever that is right in front of it. I can move the lever by hand- I assume it controls the heater. Does anyone have the fitting that would be attached to the end of the cable to allow it to control the lever?
Thanks in hope...
Andrew.
http://picasaweb.google.com/lh/photo/FFDyqnpc1LdUfOK7nTlDonWulYf22C1mq-i_F8BElsU?feat=directlink
Montecarlo S2 Spyder
HPE VX
Y10 GTi.e. x2
Re: HPE HEATER CABLE
« Reply #1 on: October 06, 2010, 12:03:23 PM »
Hi,
what do you have on the end of the cable (just the bare inner pull cable ?)
do you have the screw and clip that holds the outer cable to the heater box ?
Geoff
Offline spud
« Reply #2 on: October 06, 2010, 12:14:03 PM »
Hi Geoff,
The cable is just bare ended. It ends at a sharp right-angle as though it would've been attached to something.
Andrew.
HPE VX
Y10 GTi.e. x2
    • My Flickr photo sets
« Reply #3 on: October 06, 2010, 12:58:56 PM »
Hi Andrew
I've just removed the dash out of a VX HPE i'm breaking, will have a look after work and report back
Tony
1981 Beta Coupe 1600
Mk7 Golf Gti
« Reply #4 on: October 06, 2010, 07:18:59 PM »
I've got the small white clip which the cable hooks into (it's off a Gamma but it looks correct)
do you need the outer cable securing clip/screw as well ?
Geoff
« Reply #5 on: October 06, 2010, 08:25:52 PM »
Is this the one Andrew? If so pm me your address and I'll pop it in the post
« Last Edit: October 06, 2010, 08:28:12 PM by TonyLanciaBeta »
Mk7 Golf Gti
Offline spud
« Reply #6 on: October 06, 2010, 09:55:00 PM »
Geoff,
Thanks for your replies mate- very much appreciated. I think Tony has the exact Beta bit though.
Tony,
Aha! That is indeed the one! Thank you so much for that- pm sent.
Cheers guys!
Andrew.
HPE VX
Y10 GTi.e. x2
« Reply #7 on: October 06, 2010, 10:12:15 PM »
No problem, we're all here to help each other.
« Reply #8 on: October 06, 2010, 10:25:01 PM »
in the post ;) , as Geoff said were all here to help  :D
Mk7 Golf Gti
