Author Topic: Wiring Harness and relay  (Read 1772 times)
Offline Palikary
  • Country: au
« on: September 07, 2025, 07:03:51 AM »
Cleaning up a Lancia Beta Coupe 2000 - series 3.
There seems to be a large wiring harness under the glovebox which is not used?
Is this normal and share same harness used for other Lancia models or can it be deleted?
Also I wanted to know what the white relay is used for that just above the drivers side speaker in the footwell.(see attached photos). Thank you!
Re: Wiring Harness and relay
« Reply #1 on: September 07, 2025, 08:18:07 AM »
It doesn't look original at all but if you're going to remove it you need to trace each wire from end to end. That may give you a clue as to what the installation is supposed to do?
« Reply #2 on: September 07, 2025, 05:33:01 PM »
White relay looks add on, as mentioned trace as to where it goes
« Reply #3 on: September 07, 2025, 09:05:50 PM »
I'd guess the white relay is a replacement flasher relay. IIRC the OE one lives around there. The bundle under the glovebox - no idea - I've never seen that.
