Author Topic: Confusion over second dizzy  (Read 12298 times)
Offline deks
  • Steve Hudson
« on: September 25, 2025, 04:47:38 PM »
So Ive spoke of this on my thread but thought I'd do a post in engines
I appear to have what looks like a distributor on the rear cam carrier
but I have a separate one in the front of the engine as per pics
Anyone any ideas and if it isnt a dizzy what is it
Re: Confusion over second dizzy
« Reply #1 on: September 25, 2025, 04:56:55 PM »
Duel dizzyies :-)
I am guessing the top one is left over from it being a Vx head?
Offline deks
  • Steve Hudson
« Reply #2 on: September 25, 2025, 05:01:39 PM »
Duel dizzyies :-)
I've not seen a VX or its engine so thanks for the feedback.
Hpe it doesn't cause me any issues going forward.
I might look to blank it off while its out I am sure that won't be too difficult to do
« Reply #3 on: September 25, 2025, 05:08:18 PM »
Most cars have the block mounted distributor. The Montecarlo/Scorpion has one mounted on the back of the rear bank, Fiat 124's on the inside of (what would be on a Beta) the front cambox and the iE and VX had them mounted on the end of the inlet camshaft where your second one is. To me this points to a head replacement from a later car? Unless it's something to do with emissions kit?
« Reply #4 on: September 25, 2025, 05:19:38 PM »
Hi Steve
The normal carb type head has the blanking plate you need and I have one or two….
As mentioned it is probably IE head unless you are really lucky and have a VX head which had larger inlet valves.
Offline deks
  • Steve Hudson
« Reply #5 on: September 25, 2025, 05:41:13 PM »
Hi Steve
Thanks Peter.
Once I have the engine out etc I will seek guidance from the knowledgable people here to try and identify the head and work on what course of action maybe needed
« Reply #6 on: September 25, 2025, 06:58:22 PM »
If you post the 7 digit cast-in number (between cyl 1 and 2 I think)
i've got a list to refer to.
Offline deks
  • Steve Hudson
« Reply #7 on: September 25, 2025, 07:10:14 PM »
Thanks Nigel. Hope to have the engine out tomorrow. I will look for numbers and share them here
Regards Steve
« Reply #8 on: September 25, 2025, 08:14:36 PM »
Steve,
Sorry, a misunderstanding.....it's visible between the spark plugs at the top.
Offline deks
  • Steve Hudson
« Reply #9 on: September 25, 2025, 08:54:30 PM »
Steve,
[/quote
No worries.  It’s still coming out tomorrow but at least I can find those details in situ 👍
Offline deks
  • Steve Hudson
« Reply #10 on: September 26, 2025, 08:52:30 AM »
Steve,
Hi Nigel. Numbers on the head are 437 2281    these were between plugs 2 and 3
regards Steve
Offline deks
  • Steve Hudson
« Reply #11 on: September 26, 2025, 10:43:37 AM »
I don't think its just the head thats not right. There appears to be nowhere to add a mechanical fuel pump that mine should be running. Its been converted to electric and I was hoping to return it to standard.
« Reply #12 on: September 26, 2025, 10:48:22 AM »
Maybe they dropped in a complete ie engine? I'm taking it that the blank in the middle of your second pic is cast or welded in? That is where the fuel pump fits, but an extra problem would be that the ie engine might not have the tab on the lay shaft to drive the pump?
Probably worth sticking with the electric pump. If done properly with a cut out switch it's usually an improvement on the mechanical set up.
Offline deks
  • Steve Hudson
« Reply #13 on: September 26, 2025, 10:53:59 AM »
yes the blank is part of the cast.  To be fair I dont mind the electric fuel pump and wouldn't even have thought about it had someone else like you mention a crash cut sensor/switch. Which I am now going to research.  The return for fuel pipe has also been disconnected but I assume this is because it would keep pumping as soon as ignition was on as the return would be sending back fuel.  I was going to reconnect that during restoration but wondering now whether I should or shouldn't.
« Reply #14 on: September 28, 2025, 07:52:00 PM »
[/quote]
regards Steve
[/quote]
Steve,
That's a fuel injected head you have. Coincidently, I have the same head on my carb-equipped engine.
Offline deks
  • Steve Hudson
« Reply #15 on: September 29, 2025, 10:16:46 AM »
regards Steve
[/quote]
Steve,
[/quote]
The head at least. due to the lack of mechanical fuel pump location I am guessing the whole engine is from an injection car. Dont know whether thats better or not and doesn't really matter to me. A few little things to iron out on that front when i get to that stage but nothing thats of concern.
« Reply #16 on: September 29, 2025, 12:16:19 PM »
I'm not sure I've seen one before with the pump mounting removed at casting  - but then all of mine have been earlier. I wonder if it's still got the annoying lobe on the auxilairy shaft ?
« Reply #17 on: September 29, 2025, 01:00:24 PM »
Hi Stuart
The IE engine I stripped had a removable plate and still had the lobe.
Offline deks
  • Steve Hudson
« Reply #18 on: September 29, 2025, 03:23:57 PM »
No idea about any of that.
its got some weird mount points either side of the block as well that look as if they are mounts for a forward mounted engine but as far as i can think back Lancia never did a RWD
None of this matters really as long as it runs though I wonder if it will cause me issues if I need to rebuild it or buy specific parts such as gaskets though I am hopefully i dont need them and it won't matter if I do
« Reply #19 on: September 29, 2025, 03:35:56 PM »
Hi Steve
The 4 bolts/studs are for an exhaust support on the normal exhaust
