Author Topic: '85 Beta instrument panel wiring  (Read 34 times)
Offline Betared
« on: September 01, 2026, 07:03:42 PM »
Does anyone know of a schematic identifying the 22 electric feeds on the rear of the instrument panel? I can figure out most of the  live feeds to the lamps but the earths are confusing. I want to check that all bulbs are getting a feed before replacing the panel.
Re: '85 Beta instrument panel wiring
« Reply #1 on: September 01, 2026, 08:39:50 PM »
Without adding colours to the wires there are three connectors on the gauges. Two on the rev counter and one on the speedo.
The horizontal one on the rev counter has 6 wires, left to right,
Rev Counter signal
Hazard
Main Beam
Sidelight
Oil Temp
Oil pressure
The vertical one on the rev counter has 8 wires, top to bottom
Low oil pressure light
Left indicator
Right indicator
Earth
Overheat warning
Water Temperature
Battery Charging
Heated Rear Window
The vertical one on the speedo has 8 wires, top to bottom
Earth
Front Fogs (if fitted)
Rear Fogs
Low Fuel
Fuel Level
Low Brake Fluid
Gearbox
Handbrake
I see only two earths on the gauge cluster if that helps!
Power for all the gauges and lights appears to come in via the Battery Warning light (Alternator charging)
And if I've got anything wrong please feel free to contradict/correct me as I'm in the process of rewiring the entire car!
« Reply #2 on: September 01, 2026, 09:36:12 PM »
Have you looked in the downloads section for car wiring diagrams?
https://lanciabeta.co.uk/forum/index.php?action=downloads;cat=3
« Reply #3 on: September 01, 2026, 09:55:50 PM »
Kudos Guy, for a really useful
list.
That took some time to assemble.
Offline Betared
« Reply #4 on: September 01, 2026, 10:25:48 PM »
Peter, I can't find the info. I need in the wiring diagrams.
Guy, that info. is exactly what I need. Initial checks with a 12v supply show me that all bulbs are operational.
Another fault I have is a non functioning rev. counter. Is there a way of testing it while I have access to the connections.
Many thanks for this info.
David.
« Reply #5 on: September 01, 2026, 10:33:27 PM »
This section is taken from the neromoto diagram and has all the instrument connections and wire colours, is that what you are after?
« Reply #6 on: September 01, 2026, 10:45:29 PM »
I did manage to repair the pcb (plastic circuit board) connectors 71, 72 and 73 with self adhesive copper tape from amazon
Offline Betared
« Reply #7 on: September 01, 2026, 10:48:06 PM »
That's very useful also Peter, I saw the schematic but didn't  enlarge it as you have done.What app. are you using.When I try to print off the full diagram the nomenclature at the bottom of the page is superimposed with the other diagram and behind the Lancia B logo. Any ideas?
