Author Topic: S4 VX headlamp relays  (Read 46 times)
Offline lancialulu
« on: October 18, 2026, 03:17:25 PM »
Am I missing something but it seems that my 84 VX coupe (and all such models) does not have the dipped headlamps controlled by relays??
It seems non-VX S4 has a relay for dipped but not on my car build
I have 9v at the bulb when on (quite dim...) whereas I have 12v at the relay controlled main beams....
I suppose the voltage drop is a combination of light control stalk and the many connections till it gets to the bulb (yes I have redone the earths)..
Re: S4 VX headlamp relays
« Reply #1 on: October 18, 2026, 08:36:21 PM »
I thought they all ran directly through the column stalk? This is why the column stalk fails eventually, relays are essential
« Reply #2 on: October 18, 2026, 09:09:31 PM »
Tim,
I've looked at my 1982 wiring charts, and it's showing relays for
main beams but not for dipped.
I installed 4 relays near the 4 lamps, and powered them from,
indirectly, the black/white permanent positive lines from each side of
the fuse/relay box.
(At the time, I hadn't realised the mains already had a relay, no matter.)
« Reply #3 on: October 19, 2026, 08:37:49 AM »
You are correct! They saved money deleting that relay which was stupid frankly. Fit a relay add LED Bulbs and see where you are going!
Offline lancialulu
« Reply #4 on: October 19, 2026, 03:58:04 PM »
I have added a relay for the dipped beams and chose to tap a fused  12v direct from the battery on basis it is a minimum 10amp draw.
