Whilst underneath on the weekend I investigated the base of the gear stick, should there be a grommet protecting from the elements? I found a pile of gloop bitumen stuff dripping out/sort of covering the hole. I might need to pull it all apart and investigate, clean check. So...
How do you test for where on the gear selector bushes and link, or should I just do it? three bushes and a link from Betaboyz right?
If there is a protection grommet, can someone share some photos of the area and grommet unless I have it wrong?
