Author Topic: SA Import Beta 2000 Coupe  (Read 71010 times)
0 Members and 15 Guests are viewing this topic.
Re: SA Import Beta 2000 Coupe
« Reply #280 on: December 13, 2025, 12:26:27 PM »
I use Moly Grease although water proof cycle grease is good. Do really clean these with parts washer thoroughly before re-grease and fit. Your nylon insert looks trashed and the bearings are missing rollers. Perhaps find some used struts to strip for parts to replace these. I think the nylon insert helps to support he struts staying centered.
Online Ferrit
« Reply #281 on: December 13, 2025, 10:10:37 PM »
and the other side is all good, in fact mint.  Interestingly the support plastic still slots in place and does its job, and the bearing will do until I find a replacement.  It easy-peasey to pull out and I need it off the drive.
I did clean and use a bike teflon waterproof bearing grease.  Good side has a messed up stud I need to sort out.
« Reply #282 on: December 14, 2025, 08:28:59 AM »
On the Stud. They can just be tapped out by putting a nut on top and tapping with the strut top supported. They only hold in place with a serration on the outer so a spare can be tapped in assuming your issue is a messed up thread that will not clean with an 8x1.25mm die.
Online Ferrit
« Reply #283 on: December 14, 2025, 09:31:38 AM »
Thanks Eric. I have found a thread here on the replacement bearings I will strat checking the sizes later.
The stud.  In the end I had to cut the nut off with a Dremil.  The thread is gone.  I have found a few similar studs but none exact.  One is from a BMW Mini strut top fixing.  I will order a few.
One sides back in and looking good.  I have a week or so until the carb top is back from Classic Carb's, after a repair.  I have a feeling the carb might need a complete refurb but I am trying the correct jets, good clean (as instructed by Classic Carb's) and float location as it should and see how that is.
« Last Edit: December 14, 2025, 09:36:55 AM by Ferrit »
« Reply #284 on: December 14, 2025, 10:27:27 AM »
Studs - I think I've got a few spare ones I had plated that I'm happy to donate to the cause. Cause I don't need them! They've been plated and should just pull into the top mount with some washers and a nut. Or a hammer. Drop me a PM?
Online Ferrit
« Reply #285 on: December 14, 2025, 10:21:48 PM »
Oh thats brilliant tvm Guy
Online Ferrit
« Reply #286 on: December 15, 2025, 04:16:16 PM »
I will finish off cleaning the rest of the carb later.  Plus been ordering stock yellow bzp nuts and bolts etc.  I have rounded off a ARB bolt on the front so might do that in a mo as I have the right HT yellow bolts for this.
I have cleaned the front ns shock out of oil and its been draining etc.  I will build it up tonight, baring the top mount etc
Online Ferrit
« Reply #287 on: December 21, 2025, 09:47:59 PM »
Yesterday was a sunny fine day.  Finally got all the wheels back on and off of its home of axle stands.  Thanks you all for your help and advice and parts.  All suspension done for the time being.
#viewfrommytea
Waiting for the carb top to come back post repair from Classic Carb and rebuilt with the right jets and a new float and needle.  Hopefully over the Christmas period in time for a couple outings.
Next it will be gear change bushes etc; valve clearances and maybe the front bumper off in Jan to try and sort out the shrinking rubbers.
Happy Christmas to you all.
Online Ferrit
« Reply #288 on: December 26, 2025, 11:22:00 PM »
Happy Christmas all.
Carb top back from Classic Carbs having been repaired.  All cleaned and correct jets loaded now ready for an install and hopefully start up in the morning.
Question - what is this hole near the base, and no its not the idle mixture, thats around the corner.  I cant find any reference to it anywhere so far
Online Ferrit
« Reply #289 on: December 27, 2025, 05:02:59 PM »
Pants!!
So carb back on and pretty much started and ran straight away.  All good.
Long story short though, ran it up to temp twice and went for a spin.  1 mile away from the house, put my foot down and bam white smoke out the back and now power.  I got it off the duel carriageway and stopped.  I coxed it home after a quick check.  I think running on two cylinders.
1 and 4 are pretty much dead and 2 and 3 were at c175 psi (really quick spin over).  Coolant gone'ish but the oil looks okay.  Head off next week.
I think in order 1234
Online Ferrit
« Reply #290 on: December 27, 2025, 05:06:44 PM »
suspension felt nice  ;D
« Reply #291 on: December 27, 2025, 05:12:48 PM »
Sorry to hear about the latest hiccup - you'll get there! Hoping to get back on my car in the coming days after a bout of flu.... Great timing.
Online Ferrit
« Reply #292 on: December 27, 2025, 05:16:21 PM »
Thanks but thinking hey at least I will get to the bottom of the state of the engine this way, and happy to do this in the winter near home rather than miles away in the Summer.  After all its a spare to the spare car ;-)
Online Ferrit
« Reply #293 on: December 27, 2025, 05:17:40 PM »
Can I change the title of my blog to 'What next?!!'  :D
« Reply #294 on: December 28, 2025, 08:56:31 AM »
Hope the block does not need a skim, just the head or just new gasket....
Online Ferrit
« Reply #295 on: December 28, 2025, 09:51:25 AM »
Me too.  I am thinking the worst, and if it has to come out its the time to go through the whole thing.  Best case if its just the HG I will sort out the broken tensioner bolt, and go through items such as water pump, exhaust manifold studs etc.
Do you remove the manifolds (both) before removing the head or after?
« Reply #296 on: December 28, 2025, 10:15:14 AM »
Have you got a replacement tensioner bolt Mark?
Online Ferrit
« Reply #297 on: December 28, 2025, 12:00:41 PM »
I have, Peter found and supplied one.  Interestingly I have read a few times (inc in my GC book) to not use it but use a HT bolt and lock nuts.
Questions I have are:
1. how best to remove head, ie manifold on or off?
2. bearing in mind I am doing this on my drive and with a reduced budget for the time being, what should I check and do as a matter or course even if the head and block is in great nick?  Obv if the engine is a mess thats a whole different longer term story.  Interestingly looking at the photos down the bore myself and friend noticed it looked like honing marks...  I wonder what I will find when I get the head off?  Cant wait but its going to be later this week.
M
« Reply #298 on: December 28, 2025, 12:24:08 PM »
Are you supposed to retorque the head after a few hundred miles? If it's showing signs of having been honed then there's a possibility that wasn't done? I'd be checking the cam box oil seals for weeping and replace them too. Disturbing the cam boxes and replacing gaskets there may lead to noisy tappets and the need to reshim them so leave well alone if the head is good and doesn't need a skim. If it does then so be it, valve stem oil seals at the same time, check the valve stems aren't bent when the head is off too. If it ran fine then they ought to be good and it's just a head gasket. New cam belt and tensioner bearing and alternator belt whilst it's all apart?
Tensioner bolts - I always used the spanner flats nearest the bracket, not the outer one when removing it. Less chance of shearing the head off. Somewhere I have a long handled, thin, straight, single ended spanner for the job. First used on my first car when the starter cable stretched and the pull lever stopped working. It was possible to push the lever on the starter motor from behind the car to get it going. (name that car!) but it is equally useful for removing and refitting a Beta tensioner spring!
Offline kbetas
« Reply #299 on: December 28, 2025, 02:47:12 PM »
FYI here are before and after pictures of the head from the rally car after the gasket went. Bought a full set of top end gaskets from Betaboyz and replaced cam belt / tensioner / water pump / cam box gaskets / oil seals. Valves etc were all ok and didnt need to replace any shims. It had probably been on the way out for a while because engine felt like we had fitted a turbo once it was all back together........
1984 HPE daily
1969 Fulvia Zagato
